W40k-6th Edition kommt 2012 !
Die Dexe ab Imperiale Armee sollen für die 6. Edition geschrieben sein, aber kam der Space Marines Dex nicht vorher? Dann müsste der doch auch überarbeitet werden.
Wobei ich auch denken würde, Chaos kommt zuerst, wenns jetzt so gepusht wird. Momentan siehts ja nach "Imperium gegen Alle" aus, mit der nächsten Edition solls wohl eher "Alle gegen Chaos" sein. Was auch erklären könnte, wieso Allierte wieder kommen.
So und hier mal ganz doof Gerüchte zum BT-Release, der angeblich vor den Tau ercheinen wird:
via ghost21
Ghost has said that BT are due out before Tau, presumably the next codex.
kits for sword brethren n nophytes(sp) as ive said im more of a xenos guy but ill provide what i know, vows are less restrictive
i also saw things for something called knights of the inner circle (or something along those lines).. they were named each came from a successor chapter, n the guy who lead them was a bt... it was interesting but as usual salt applies
Not as big! But more bizarre! (unless you play fantasy...). That's most of what I know about it. Speculating from that - big buffing thing with a howdah ?!
A bit more for now - in regards to the 'neophytes' (if they continue with that name), I heard they were finecast. Whilst it would leave room for another plastic kit, I hope this isn't true.
Dark Angels are not at all on my radar, doesn't mean they aren't happening anytime soon, but I haven't heard a thing, if ghost's heard anything it is likely to do with black templars.
"Phill kelly is going to write the Bt codex, so that should be great oh and new units added for bt as well.
via Jared van Kell
- Phil Kelly is writing the Codex.
- More emphasis on the horde aspect of the army with lots of large units of Initiates and Neophytes.
- Emperors Champion is more in line with the company champion of the Grey Knights but is still 2 wounds. Gains preferred enemy against independent characters and monstrous creatures.
Some additional bits.
- I forgot to mention the Rightous Zeal rule could be changing to be more along the lines of the Rage USR. Something along the lines of if they fail a Ld test then they are subject to Rage and must advance towards the nearest enemy unit. As yet the details are sketchy.
- All the current special characters (ie: Helbrect and Grimaldius) will remain. Also I had heard of an mention of a special character who is like the greatest of all of the Emperor's Champions and the greatest warrior in the Black Templars. I had heard mention of a bike mounted special character with a lance like weapon but I cannot confirm this yet. "
via Harry
I certainly heard about these guys before heard much about Tau .... the order I hear about them was Necrons and Sisters at the same time, Black Templars then Tau.
Not sure what the story is with Sisters but they must be in the mix somewhere.
Quelle: http://natfka.blogspot.com/2011/11/black-templar-finally-some-rumors.html
Ich halte die Aussage mit den Edi6 Kodices für virales GW Marketing. Wieso? Der Kodex DE sieht nicht nach Edi6 aus, sondern nach Edi4. Der wurde dann einfach mit der heißen Nadel noch mal auf edi5 umgestrickt. Kann man meiner Meinung nach daran sehen, dass viele verteure Einheiten (wie die Antigrav-Fahrzeuge) mit Edi4 Regeln halbwegs ihren Preis rechtfertigen und die Preispolitik generell viel näher an den Punktkosten aus dem Edi4 Kodex Eldar liegt und nicht so recht in die Senkungsorgie paßt, die P.Kelly dem anderen von ihm verzapften Edi5 Kodex spendiert hat (Space Wolves).
Aber wenn die Community eben glaubt, dass GW mit einer Weitsicht von 2-3 Jahren Vorlauf seine Kodices&Editionen schreibt, verzeiht man so Verbrechen wie den Kodex Tyras vielleicht eher.
Ich kann jetzt leider die gestrigen Gerüchte von BOLS nicht posten (Arbeit und so), scheint sich aber mit dem hier zu widersprechen. Dann heißts wohl wieder warten und sich überraschen lassen.
Kurz zusammengefasst:
Codex Eldar kommt vor Release der 6. Edi. Autor is Kelly (???)
6. Edi ist in der Testphase und kommt im Juni oder Juli
Starterset ist evtl. Fall of Damnos. Wird aber auf jeden Fall Marines beinhalten.
CSM kriegen einen der neuesten Dexe in der 6ten...gleich nach SM (!!!!!!)
Tau und BT kommen dann nach CSM. Viel mehr wird angeblich nicht mehr upgedatet in der 6ten weil die Regeln ab Imperialer Armee beginnend bereits für die 6te gedacht waren. "der der nicht genannt werden darf" schreibt evtl. den BT UND den Tau dex. Und nein es ist nicht Cruddace. DA werden so schnell nicht upgedatet weil sie zu unbeliebt sind und GW dafür kein Geld rausschmeißen will.
Soll jeder selbst entscheiden was er für richtig hält und was nicht 🙂
Wobei ich mich frage was sie dann in der 6ten machen wenn keine Codizes upgedatet werden? Daumen drehen? 😀
Ich glaube des war eher so gemeint (wie auch beschrieben), dass die in der 5ten rausgekommenen Codizes nicht geupdated werden. Da aber die andere Hälfte neu rauskommt kann man wohl nicht von Däumchen drehen reden.
Das heißt folglich (wenn DIESES Gerücht jetzt halt stimmt), dass die Regeln sich nicht so grundlegend ändern können, da sonst massive Regelupdates der bestehenden Codizes notwendig wären. Was wiederum zu der Annahme führt, dass einige der REgelgerüchte schlicht nicht stimmen können.
Also die Regelgerüchte die ich bis jetzt gelesen habe, finde ich schon zu 100% Kompatibel mit den existierenden Codizies muss ich sagen. Wüsste jetzt spontan nichts was mit einem Codex inkompatibel ist.
@Galatea
40K ist ja bei einem Punkt angekommen wo zumindest Ich persöhnlich dankbar für jede kleinste Änderung bin. Selbst wenn es zu dem Preis ist das es wieder 2 neue dämliche Regelungen gibt.
Ein konkretes Beispiel dafür ist, das es wohl Reaktionenmöglichkeiten gibt um sich vor Schaden durch gegnerischen besser schützen zu können bzw. auf diesen zu reagieren.
Meine Freude darüber war aber gleich wieder relativiert da die meisten Aktion, sofern Erfolgreich, darin resultieren das die Einheit Niedergehalten ist. Was ja nichts anderes bedeutet als das ich Modelle zwar gerettet habe aber effektiv einen Spielerzug lang nichts mit Ihnen anfangen kann. Und wenn es dumm läuft werden Sie im darauffolgenden gegnerischen Spielzug doch noch vernichtet.
Das ist es was ich echt Schade finde das es GW nicht schafft von dieser Ganz oder Garnicht Geschichte wegzukommen! 🙁
