Tyraniden Release Jan. Regelflut!!! (Update 09.01.2014 #1)
Naysmith
06. November 2009
14.124
20
14.606
157.066
Führte nur zu Verwirrungen daher aus dem Sichtfeld
Das habe ich gerade bei faeit212 gefunden:
Tyranids
I have had another confirmation of Tyranids in November, but that will difficult to get more information during the weekend. This is one codex that I am excited about, and looking forward to even more than Marines. Simply because I have felt that they took it in the backside when it comes to the allies chart, and some of their units.
Tyranids are just so iconic, that I cannot wait to see them on the field. I am hoping that we will be seeing Imperial Guard afterwards, so that we can have some very classic 40k battles raging on the tables soon.
Auch wenn er nicht immer absolut richtig lag war die Richtung nahezu immer korrekt. Daher besteht Hoffnung für die Tyraniden noch in diesem Jahr! Bei der Schlagzahl die GW momentan an den Tag legt halte ich es für gut möglich das es stimmt.
Gut, stimmte nicht 😉.
OLD News 13.08.2013 - 26.11.2013
13.08.2013
New Flyer - Fast Attack choice, the alternative build for the Harpy kit.
Ymgarl Genestealers - Special arrival rule is shared with the Lictor, may now purchase standard Genestealer biomorph upgrades.
Hiveguard: new weapon upgrade option (available to a handful of units) that grants skyfire with an "enhanced ability" to ground FMCs
Via Faeit212
Finally some details on what we might be seeing in the new codex. A huge thanks to our source, for helping stay on track and with some details for Tyranids.
Please remember that these are rumors
via a strong source here on Faeit 212
Tyranids, at least at current can ally with themselves essentially.
They have the standard:
2 HQ
6 Troops
3 Elites
3 Fast Attack
3 Heavy Support
And can take an optional
1 HQ
2 Troops (not minimum 1, up to 2, but instead MUST take 2 and then...)
And if they do, it unlocks
1 Elite
1 Fast Attack
1 Heavy Support.
Only an HQ from the core can be warlord.
Then the diversity comes into play.
Hive Fleets now have different rules (think chapter tactics). Your secondary brood can be from a different hive fleet. Not representing two fleets working together, just similar evolutionary strains.
There are also army wide FoC changes based on your Hive Tyrant. Wings give you the option to take Gargoyles as your compulsory troops (so max 2) for instance. Bonded carapace let's you take Carnifex's as elites as well as heavy support (but can't be more than a certain number of points, so they end up kinda baby).
They have some really cool adaptations for skyfire.
Warriors can be purchased as sergeant style upgrades for gaunts and gargoyles. They get the biomorphs of the brood and are not attached like wolf guard.
Tyrannofex will see a points decrease.
Pyrovore will see torrent.
Ranged biomorphs contribute to a model's close combat.
Melée biomorphs enhance a model's ranges attacks.
You take some biomorphs that affect both, like +1 str to both.
But having a gun makes melée better and having melée weapons improves your guns. There's some new synergy there. Mostly for big bugs.
Psychic ability is a lot worse than what it is now, but it'd be difficult to explain and just upset people who don't have the whole picture.
All of this is subject to change and about a month old.
Bei dem folgenden Gerüchte Sammelsurium bin ich sehr skeptisch! Vermulich ist das meiste Wishlisting und das wenigste war. Na ja warten wir es mal ab.
Via faeit212
There is a large group of Tyranid rules that are now floating around on 4Chan and all the forums by now. Its hard to tell how good of a rumor this is, so take it with a little extra salt until we can get more information. In my opinion, if this is real in any way, its from playtest material.
Please remember that these are rumors, please add some extra salt on this one.
Via 4chan:
Army-wide notes
- No FOC and ally table changes
- Devastation and Adaptation are new power tables with 3 powers each + primaris.
- Primaris for Devastation = Warp Blast, Adaptation = Onslaught (similar to battle-focus)
- All Tyranid powers can be used with either one or two charges to increase the effect.
- Ravenous Advance: Units with this rule can run & assault in the same turn.
- The Ground Trembles: All MC cause d3 Hammer of Wrath hits.
- Red Terror, Deathleaper and Old One Eye are unique upgrades to their respective broods.
-Harpy/Erinye, plastic dual kit.
- Harpy is designed to kill infantry hordes/provide support via its special vector strike.
- Vector striking it can either use Spore Mine Cyst to create blasts along the path or Sonic Screech to halve initiative and cause a pinning test.
- Erinye is an AA variant in Elite, very different front torso/head piece with gribbly tentacles.
- Increased Swoop speed and its gimmick is grappling other flyers.
- Vector strike -> dice roll 4+ -> the enemy flyer is dragged directly behind where the Erinye ended its move, including a new facing.
- Both can buy broods of Gargoyles that can drop off in the movement phase when not vector striking.
-Zoanthrope (Doom)/Genethrope, plastic dual kit.
- Zoanthropes are ML1 psykers, have access to the Devastation, Telepathy, Telekinesis tables.
- Genethropes are similar, but have access to the Adaptation and Biomancy tables.
- New unique biomorphs. Increased Shadow in the Warp range, Deny the Witch boost aura, two others.
- Both types can upgrade up to ML2 but only ever get 1 power, each Elite choice is a unit of 1-3 that can contain mixded Zoan and Gene.
- Doom has access to all the above tables and comes with Essence Leech and 3 powers.
- Consumes a wound every time it uses a power (except for Leech), but can keep casting until a Perils roll or its down to 1 wound.
Mycetic Spore/Mycetic Hive Node, plastic dual kit
- Spore is a Dedicated Transport, notable changes are that SC can join and MC broods can all opt to get spores.
- Hive Nodes are bought by HQ models (1-3 choice for Tyrants, 1 for every other HQ), no transport capacity.
- Nodes provide Synapse and can be configured in one of many ways. Grants poison or shrouding to nearby units or terraforms (Dangerous Terrain) the surroundings.
Carnifex
- Old unused bimorphs in the box are options again.
- Base cost the same but upgrades are much, much cheaper overall but lots of "only buy 1 out of this list" kind of choices which greatly limits what a fex can have.
- Tusked gives HoW an AP value, Thornback increases the number of HoW hits.
- Enhanced Senses gives Night Fighting.
- Tail Scythe & Tail Mace each deliver a single hit to all models in BtB at Ini 1, with different stats.
- Living Battering Ram rule: Changed to allow the Carnifex to assault the contents of a building/transport on a 4+ if it was destroyed by its charge, rolled once for the brood.
22.08.2013
Via faeit212
via an anonymous source on Faeit 212
He states these rules are BETA and are around 7 month old
Hormagaunts :
may add an additional 20 Hormagaunts
Equipment: scything talons & adrenal glans
upgrades:
toxic sacks : (remain the same)
piercing talons : (+1 strength)
tyranid warrior (squad leader):
special rules:
leap, they just keep coming,synaptic back lash (tyranid warrior only) synapse creature (tyranid warrior only)
leap: may charge +6'' extra & do not lose initiative while charging through difficult terrain
they just keep coming: enemies firing at models with this rule suffer -1 bs
models with BS 1 must re-roll any successful hits on a model with this target.
synaptic back lash: after a model with this rules dies then all friendly units within 6'' of the models death suffer a single strength 3 AP - hit.
Old one eye to have his toughness increased
tyranid warriors
may add an additional 3 models
WS T SV
5 5 4+
Equipment:
piercing talons, leap, synaptic back lash,
special rules: will of the hive mind
upgrades:
toxic sacks: (read above)
adrenal glands: (read above)
range biomorph exoskeleton: (+1 bs)
increased exoskeleton: (+1 sv)
barbed strangler: (remains the same)
venom rifles: (tyranid rifles with poison) 18'' range (under re-testing)
will of the hive mind: while the squad remains with the full 3 models then the synapse range increases to 12''
carnifex:
may add an additional 2 models
T W
6 5
Equipment:
scything talons, piercing talons
special rules: rampant rage, living battering ram, natural disaster
upgrades:
Toxic sacks:
armoured shell: (2+ save)_
crushing claws: (+d3 attacks & +1 to range AP)
reinforced plating: (reduced strength of weapon being fired at you by 1)
heavy venom cannon: (strength 9 AP 2 heavy 2)
barbed strangler: (strength 5 AP 5 large blast, pinning)
twin linked devourers: (strength 4 AP 6 assault 4)
rampant range: when charging units the carnifex gains rage & furious charge)
Living battering ram: the carnifex deals d3 hammer of wrath hits
natural disaster: if the carnifex forgoes its turn in a piece of terrain (ruins ect) it can destroy that terrain and remove it from play
25.08.2013 Zusammenfassung von BolS wenig neues aber recht glaubhaft in meinen Augen.
Here is your weekly round up of everything we have seen the past seven days.
TYRANIDS
A whole bunch of rumors are leaking on the next codex after the Marines, the bugs! Here is one giant mash-up of all the rumors that hit BoLS.
Carnifex - significant cost reduction
Harpy – big overhaul. New model/dual-combo kit, Flying Monstrous, Sonic Screech combines with Vector striking. Additional Spore Mine Cysts may be purchased as upgrades. Default Stranglethorn has new upgrade options.
Hiveguard: new weapon upgrade option (available to a handful of units) that grants skyfire with an "enhanced ability" to ground FMCs.
Tyranids will get a massive overhaul with Psychic powers. Look for many new non-overt force powers that represent the chilling, horrific, warp-stifling power of the Hive-mind.
Aside from a few old chesnuts, look for almost all new Tyranid enhancing abilities, and other new chilling and damping abilities to use on enemies of reflect the horror, hopelessness, and dread of fighting the swarms under the psychic interference of the hivemind.
Look for concepts such as dampened psychics for opponents mixed with bio-enhancement powers to bolster the swarms.
Shadow in the Warp will remain in the codex, but receive a controversial overhaul.
More existing units will have the option of manifesting Psychic powers.
Army-wide notes
- Harpy/Erinye, plastic dual kit.
26.08.2013 Via faeit212
Playtest Regeln HQ
I want to spend a moment to add some extra salt to these. The source is adamant that these are from a playtest set, while according to another, these do not match up. So why post them up? Because they are rumors, and there is always the possibility that there something to them. There is no direct line to GW to tell me if these are in fact real or not, and if there was, they wouldnt say either way.
The source that sent them in, has been correct before and is a good source, but remember to please use a little extra salt with this set.
This is from the latest test codex to finalize the rules for the upcoming codex.
HQ:
Hive tyrant:
WS BS S T W I A LD SV
8 4 7 7 5 6 5 10 3+
composition: 1 Hive tyrant
Unit type: monsterous creature
Weapons and biomorphs:
Bonded exoskeleton
bone sword (challenge weapon)
lash wip (changed: -4 to enemies initative)
scything talons
special rules:
Synapse creature
psyker mastery level 3
overlord (+1 to movement & charge distance for army until death of unit)
shadow in the warp (changed: -4 to enemy physic tests within 12'')
leaderless (death of unit will cause strengh 4 AP - hits to all units within 12'')
physic powers🙁under testing)
options:
add an additional set of scything talons: free
replace scything talons with heavy venom cannon:
stranglethorn cannon: (changed: 15pts)
twin linked death spitters: (changed: strength 5 AP 4 assault 4) :
may take the following:
Adrenal glands: 5pts
toxic sacks:
acid blood:
implant attack : (changed: challenge weapon) :
toxic miasma:
regeneration: (changed: 5+ to regain a wound at the end of the turn) :
Alpha regeneration: (4+ to geain a wound at the end of the turn):
May take up to two upgrades:
armoured shell:
wings:
spore field (-1 to enemy BS when firing at model):
physic shield (4+ invunrible save)
Swarmlord:
10 0 8 7 6 7 6 10 2+/4+
Composition: 1 Swarmlord
Unit type: Character Monsterous creature
Bonesabres (challenge weapon)
armoured shell
physic shield
special rules:
synapse creature (18'' range)
phyker mastery level 4
swarm leader: (changed: give one unit: rage, fear or feel no pain)
undying beast: gains eternal warrior special rule
blade parry: (changed: gains +1 attack for every enemy model in base contact. striking at initative step 7)
shadow in the warp
painfull loss: (once the unit is killed ALL models must take a unmodified leadership test (including units under synapse) the amount you fail by
on your leadership test is the amount of wounds a unit must take)
physic powers: (under testing)
Tervigon:
4 0 6 6 6 1 2 10 3+
Composition: 1 tervigon
unit type: monsterous creature
weapons and biomorphs: (Unchanged)
special rules:
synapse creature: (12'' range)
brood progenitor
pysker mastery level 2
shadow in the warp
spawn termagaunts
it will not die
Must take one of the following:
scything talons:
piercing talons: (+1 stength)
crushing claws: (changed:
spore field:
can take one of the following:
adrenal glands :
toxic sacks:
acid blood:
toxic miasma:
regeneration:
Tyranid prime:
6 4 6 5 4 5 4 10 3+
Composition: 1 tyranid prime
unit type: infantry
scything talons
rending claws
implant attack
special rules:
synapse creature🙁6'')
alpha warrior: (changed: if unit joins warriors then synapse range increases to 12'' also allows squad to use WS)
shadow in the warp
replace scything talons with:
pair of bone swords (changed: challenge weapons) :
lash wip and bone sword:
adrenal glands:
toxic sacks:
regeneration:
physic shield:
ranged weaponry: (under going beta testing)
The parasite of mortrex:
6 0 5 5 2 6 3 10 3+
Composition: 1 parasite of mortex
unit type: jump infatry
weapons and biomorphs: (unchanged)
special rules: (unchanged)
Hive guard:
You may include a squad of hive guard if you take either the hive tyrand or the swarmlord
(these do not count towards your HQ slots)
4 0 6 6 1 4 3 7 3+
Unit composition: 1-3 hive guard
unit type: infatry (character)
rending claws
scything talons
boned exoskeleton
special rules:
instinctive behaviour - feed
blind rampage
rage
shield wall
lash whip
Playtestregeln Elite
As in the previous set, please remember that these are rumors and require a little extra salt
Elite
Hive Guard brood
4 4 5 6 2 1 2 8 3+
Composition: 1-3 hive guard
unit type: Infantry
Claws and teeth
impaler cannon
bonded exoskeleton
special rules:
instinctive behaviour - lurk
sky fire
interceptor
weaponry: (changed : strength 7 AP 3 assault 3) Note: guns no longer ignore cover saves.
Lictor brood:
7 4 6 4 2 8 3 10 5+
Composition: 1-3 lictors
Unit type: infatry
chameleonic skin (changed: +1 cover while in jungles and ruins)
flesh hooks (changed: range 12'' strength 6 AP 2 assault 2 pull) - pull: pull an indipendant character out
a unit and into combat
reinforced chitin
rending claws
scything talons
special rules:
prey: (pick an indipendant character at the begining of the game, able to re-roll hits & wounds against that target)
fleet
counter attack
move through cover
stealth
natual reflexes (5+ invunerable save)
spore field
Venomthrope brood:
3 0 * 4 2 4 3 7 5+
Composition: 1-3 venomthropes
unit type: infatry
lash whips
reinforced chitin
toxic miasma
speical rules:
spore cloud (changed:5+ cover save for all units in 6'' & strength 6 AP - hit for all enemy units within 6'')
toix touch (wound on 2+)
spread poision: (grants a unit within 6'' the poision special rule)
spore field
Zoanthrope brood : (non completion until psyic powers finallised
doom of malan'tai: (non completion until psyic pwers finallised
Pyrovore brood:(changes)
. +1 toughness
. +1 wound
. weapon now has torrent
Ymgarl geanstealers:
5 0 5 4 1 6 3 10 5+
unit composition: 5-10 ymgarl geanstealers
unit type: infatry
rending claws
reinforced chitin
special rules:
rage
brood telephathy
fleet
move through cover
toxic cloud (units may not overwatch against this target)
bounderble leap (+6'' charge range and ignores effects of difficult terrian)
Via BolS 27.08.2013
They rain down from the Hiveships, gelatenous bags of vile ichor and malevolence. Here's the latest word on the Mycetic Spore said to arriving with the upcoming Tyranids.
-Mycetic Spore is coming with the new Tyranid release
-Plastic combo-kit that makes the Spore and another large bug.
-It is an enormous creature, with an immense abdomen/transport sac, that spills over the sides of a standard oval base.
-It has tiny vestigial arms similar to a Zoanthropes, and a head with a tentacle ringed maw.
-The giant abdomen/sac looks swollen, and has internal protuberances looking like Tyranid creatures are stretching the skin from within, about to rip their way out...
-It has forward arms options that can be upgraded for various biomorph/weapon options.
-The secondary creature build option replaces the abdomen/sac with something entirely different.
Via faeit212 28.08.2013
via a reader here on Faeit 212
I got some pictures to share that I took. I am sure you will enjoy them.
Nick PowellAugust 27, 2013 at 8:29 PM
Since its likely that the actual codex has already been set to print/ship by now, I'm sure this is specifically for November white dwarf army pics/battle report. With the new version of white dwarf (ok not that new, about a year old now), they can print them very quickly and make changes up until a few weeks before release, something they weren't able to do with their old printing contracts.
04.09.2013 Neues Round up via Faeit212
Please remember that these are rumors.
Compiled via Zion at Tabletop Wargaming
Codex Information
Author:
State: November 2013 or January 2014 (there is a lot of contention at the moment about this)
General Information
  • None
New Codex Rules
  • Altered FOC allows you to gain +1 Elite, +2 Troops, +1 Fast Attack +1 Heavy Support when you purchase a 3rd HQ Slot.
  • Only an HQ from the primary detachment may be chosen as the army's Warlord.
  • Two psychic powers lists: Devastation and Adaptation
  • Devastation's Primaris: Warp Blast; Adaptation's Primaris: Onslaught (similar to Battle Focus)
  • All Tyranid Psychic Powers may be used with 1 or 2 Warp Charges, using more Warp Charges increases the effect
  • Psychic ability is "a lot worse than it is now"
  • Hive Fleets now have different rules (think Chapter Tactics from Codex: Space Marines).
  • The allied detachment may be a different hive fleet (it doesn't count as a different Hive Fleet, just similar evolutionary strains).
  • Army wide FOC changes based on Hive Tyrant. Wings allow you to take Gargoyles as your compulsory Troops (max 2), Bonded Carapace lets Carnifexes be Elites and Heavy Supports (though there is a points cap on how much those Elite 'Fexes can cost).
  • Warriors may be taken as Sergeant Style upgrades for Gaunts and Gargoyles. They get the same biomorphs as the rest of the unit and are not attached like Wolf Guard.
  • Ravenous Advance: Units with this rule may run and assault in the same turn
  • The Ground Trembles: All Mounstrous creatures do D3 Hammer of Wrath hits.
Wargear/Biomorphs:
  • "Really cool" adapatations for Skyfire
  • Melee biomorphs contribute to models ranged ability
  • Ranged biomorphs boost model's melee abilities.
  • Lash Whip now give -4I
  • Bone Sword: "challenge weapon"
  • Implant Attack: "challenge weapon"
  • Regeneration: 5+ to regain wound at end of turn
  • Alpha Regeneration: 4+ to regain wound at end of turn
HQ
Models:
  • Tyanid Prime (Plastic Clamshell): Larger Warrior with a 4 pronged headcrest, additional shoulder plates that interlock down over part of the chest, armor is sharper and extends outward with slight upward curve. "Looks like you could impale a Guardsman on its back." Is on foot with Devourer and Scything Talons. Compatible with Warriors and Ravener kits for other weapon options.
  • Parasite of Mortrex (Clamshell package)
  • "Big Bug": Larger than Tervigon, stands on oval base, hunched over, but wider. $115 USD
  • Tyrant Guard: Share a kit with Hive Guard. come with full options for both units.
Rules:
"Big Bug":
  • 18" Synapse,
  • Mastery Level 4,
  • "Prime Version" grants Feel no Pain and Counterattack to Tyranids in 12".
  • Stat line like Tervigon, but A2. Has Shadow in the Warp.
Tervigon:
  • +1WS, -3BS, +1S, +1T, +1W, -1A
  • 12" Synapse
  • Mastery Level 2
  • Brood Progenitor
  • Shadow in the Warp
  • It Will Not Die
  • Spawn Termagants
  • Can upgrade to spawn Tervigons with full options but for a steep price.
  • Must take one of the following: Scything Talons, Piercing Talons (+1 Strength), Crushing Claws, Spore Field
  • May take Adrenal Glands, Toxin Sacs, Acid Blood, Toxic Miasma, Regeneration
Hive Tyrant:
  • +1BS, +1S, +1T, +1W, +1I, +1 A;
  • Mastery Level 3,
  • Comes with: Bonded Exoskeleton, Bone Sword, Lash Whip, Scything Talons.
  • New Rules: Overlord: +1 to movement & charge distance for the army as long as he's alive; Shadow in the Warp: -4 to enemy psychic tests within 12"; Leaderless: Death of Hive Tyrant causes S4, AP- hits to all units within 12".
  • May take a second set of Scything Talons (free), replace Scything Talons with Heavy Venom Cannon, Stranglethorn Cannon or Twin-linked Death Spitters (S5, AP4, Assault 4)
  • May purchase Adrenal glands, Toxin Sacs, Acid Blood, Implant Attack, Toxic Miasma, Regeneration, Alpha Regeneration
  • May also take up to two of the following: Armoured Shell, Wings, Spore Field (-1BS to enemy when they shoot at model), Psychic Shield (4++ Invulnerable Save)
Swarmlord:
  • +1WS, +2S, +1T, +1I, 2+Sv/4++
  • Mastery Level 4
  • Weapons and Biomorphs: Bonesabres (challenge weapon), Armoured Shell, Psychic Shield
  • 18" Synapse range
  • Swarm Leader: Gives 1 unit Rage, Fear or Feel no Pain
  • Undying Beast: Eternal Warrior
  • Blade Parry: +1 Attack for every model in base contact, at I7
  • Painful Loss: When model dies ALL models must take an unmodified leadership test (including those in Synapse), for each point they fail by is how many wounds the unit suffers.
Tyranid Prime:
  • +1S, +1W
  • Weapons and Biomorphs: Scything Talons, Rending Claws, Implant Attack
  • 6" Synapse (increased to 12" when in Apex Brood? Some differing rumors here).
  • Apex Brood: Prime may take a single retinue of "Apex" Warriors, Raveners or Shrikes. They recieve +1WS/+1BS/+1T and automatically pass Look out Sir! rolls while the Tyranid Prime is attached to the Apex Brood (Apex Brood is 5-10 points more expensive per model depending on the unit).
  • Hunter-Killer: Enemy Characters cannot refused challenges from the Prime.
  • May take: Adrenal Glands, Toxin Sacs, Regeneration, Psychic Shield
  • Fluff now details that it's designed to be the perfect warrior, created to fit any battlefield and seek out and enemy commanders while supported by specially evolved broods.
Parasite of Mortex:
  • +1WS, -3BS, -1S, +1T, -1W, -1A
  • Jump Infantry
  • Weapons and Biomorphs: Unchanged
  • Special Rules: Unchanged
Hive Guard:
  • -1WS, +1S, +1T, -1W
  • Unit 1-3 Hive Guard
  • Infantry (Character)
  • Weapons and Biomorphs: Rending claws, Scything Talons, Bonded Exoskeleton
  • Special Rules: Instinctive Behaviour - Feed
  • Blind Rampage
  • Rage
  • Shield Wall
  • May take: Lash Whip, Bonesword
Mycetic Hive Node:
  • Bought by HQ Models (Hive Tyrants: 1-3, Else 1)
  • No transport capacity
  • Provide Synapse
  • Can be configured to give units in range poison, shrouded, or terraform the surrounding terrain (makes it Dangerous Terrain)
Elites
Models:
  • Doom of Malantai (Clamshell package)
  • Hiveguard: Share a kit Tyrant Guard. 3 Models, with all the options for both units.
  • Erinye: Dual kit with Harpy. Different torso/head piece with gribbly tentacles
  • Zoanthrope (Doom)/Genethrope: Dual Plastic Kit
  • Crawling Plague: Named Venomthrope. Finecast. Has 3 rows of vents on its back, has a longer tail that wraps around a piece of scenery. Mouth tendrils are shorter and spread open around the mouth. Looks like it's about to spit something, and has liquid dripping from it's maw.
Rules:
Pyrovore:
  • Gains Torrent
Hive Guard:
  • New weapon upgrade (available to a limited number of units) that grant Skyfire with an "enhanced ability" to ground FMCs.
Lictors:
  • Small price bump,
  • Gains new rule: "Surprise!" - All shots against Lictors the turn after they appear are snapshots.
  • Deathleaper is now an upgrade character.
Ymgarl Genestealers:
  • Gains Lictor's "Surprise!" rule,
  • May purchase standard Genestealer biomorphs.
Erinye:
  • AA Variant Flying Monstrous Creature
  • Increased Swoop Speed
  • Grapples Flyers: Vector Strike, on a 4+ enemy flyer is dragged directly behind Erinye ended it's move, including a new facing
  • Can buy brood of Gargoyles to drop off during Movement phase on turn it doesn't Vector Strike
Zoanthropes:
  • Mastery Level 1
  • Devastation, Telepathy and Telekinesis Tables
  • New Biomorphs: Increased Shadow of the Warp range, Deny the Witch aura boost, "two others"
  • May upgrade to Mastery Level 2 but may only have 1 power
  • May be taken in the same Brood as Genethropes
Genethropes:
  • Mastery Level 1
  • Adaptation and Biomancy
  • May be taken in the same Brood as Zoanthropes
Doom of Malan'tai:
  • Has access to Devastation, Adaptation, Telepathy, Telekenisis, Biomancy and comes with Essence Leech and 3 powers
  • Consumes a wound every time it casts a power (except Essence Leech), but can keep casting as long as it doesn't Perils or end up down to 1 wound (this means a max of 9 powers a turn)
Venomthrope:
  • Venomthropes create 5+ cover
Crawling Plague:
  • New Venomthrope character.
  • Has Torrent Weapon: AP-, Poison 4+. On a 3+ place a marker anywhere on where you placed the template. On the following turn place the small end of the flamer template on the marker and aim it in any direction. On a 4+ the marker stays in play (test each turn).
  • Gives Stealth to all models in 6", and has shrouding.
  • "It Lurks in the Mists": Instead of deploying on the board may be deployed at the start of any movement phase within 6" of any Venomthrope.
  • Is a mutation from Hive Fleet Karkinos who is specialized in toxic weaponry and Venomthropes.
Troops
Models:
  • Termagant (recut for more options: Spike rifles and Strangleweb, curled tails, Rippers no longer on sprues)
Rules:
  • Termagants gain fleet
Dedicated Transport
Models:
  • Mycetic Spore: Kit also makes Mycetic Hive Node model. Bell of Lost Souls said the following baout the new model:
  • -It is an enormous creature, with an immense abdomen/transport sac, that spills over the sides of a standard oval base.
Rules:
Mycetic Spore:
  • Special Characters may join broods in pod
  • Monstrous Creature Broods may take Mycetic Spore Pods
Fast Attack
Models:
  • Harpy: Looks like image in codex, and is roughly the size of a Heldrake. "Dual-combo kit" with Erinye.
Rules:
Harpy:
  • Flying Monstrous Creature,
  • Vector Strike may either useSpore Min Cyst to create blasts along the path or Sonic Screech to half Initiative and causes a pinning test.
  • May purchase additional mines.
  • Stranglethorn Cannon may purchase new upgrades.
  • Designed to kill infantry hordes and provide support with its specialized Vector Strike
Raveners:
  • Red Terror is an upgrade character
Heavy Support
Models:
  • None.
Rules:
Carnifex:
  • Base cost the same
  • Upgrades "much, much" cheaper
  • Upgrades have a number of "may only purchase 1"
  • Tusked: Hammer of Wrath gains an AP value
  • Thornback: Increases the number of Hammer of Wrath hits
  • Enhanced Senses: Night Fighting
  • Tail Scythe and Tail Mace: 1 hit to all models in base to base contact at Initiative 1, with different stats
  • Living Battering Ram: Changed to allow Carnifex to assault contents of a building/transport if it was destroyed by the Carnifex's charge on a 4+. Roll once per brood.
  • Old One Eye is an upgrade character
  • All the options in the box are usable again
Tyrannofex:
  • Points reduction.
06.09.2013 Via BolS
Karkinos:all you zodiac lovers will appreciate the reference. It is not known what form this Classical Greek monster will take in the new Tyranid codex, only that it is coming. Here is what else is on the way:
Monstrous Creature Broods may not deploy in multiple Mycetic Spores. ~YIKES!!!
HQ Trygon option.
Parasite is now a Shrike upgrade character, and moves out of the HQ section.
Tyranid Prime can now be purchased in Warrior, Shrike or Ravener forms.
Many classic biomorphs have returned as upgrade options for most units.
Many units can now run twice or run-assault. ~ nice countpoint to Battle Focus
New unit that is static but extends synapse range. Can take some weapons and has cc ability if attacked.
5 new units in the Tyranid Codex:
-New flyer (Erinye)
-Mycetic Spore combo-kit alternative build (Mycetic Hive Node)
-Entirely new Monstrous Creature (the "Big Bug)
-New elite character (Crawling Plague - Named Venomthrope)
-Another one... (Genethrope)
This set is also lining up with most of the previous rumor sets (see below link). 5 new units isn't too bad considering the large number of missing models that need to be filled out from the last codex.
03.10.2013 Via faeit212
via Hydra on Warpshadow
The emperors tarot points straight on January for the big release we are all waiting for.
A Lictor of mine told me, that the skymother will bring us new goodness at the start of the next year.
Magos Kelly asked about this, just smirked and reminded me about the trouble he got into the last time something passed his lips.
You should have seen the glitter and the endless hunger in his eyes...
No new Hormagaunts or Termagaunts
Have to let you down.... no horma or termagants coming up...
Aktuelles 29.10.2013 Via BolS
via the whispers in the wind...
First off, as with our previous rounds of rumors some ratings.
We rate these probable, coming from solid sources
Bugs, bugs, and bugs in Q1 2014
Tyranids
-Tyranids kick off 2014 ~so look for pictures and craziness to ensue in the December rampup
-An emphasis on making EVERY unit in the codex viable this time around ~we're looking at you Pyrovore!
-The army rules and theme are focused on adaptability of unit abilities and inter-unit synergy ~there will be "combos"
-Emphasis on model releases will be to get out all the missing models in the previous codex
-Look for a small number of highly specialized new units to shore up 6th edition deficiencies in the army
-A new unseen big bug kit is among these
Via Faeit212
Tyranids are very much expected to be released January 4th, with pre-orders starting a few days after Christmas on the December 28th. ...
02.11.2013 via BolS
We rate these possible, coming from mixed sources
Tyranid Named Characters
Unique Tyranid creatures are unique per detachment. For for example 2 Dooms, 2 Swarmlords, etc... at 2k, representing a very rare breed but something that each HiveFleet knows how to create in extremis.
05.11.2013 via BolS
"The Dominar embodies Tyranid Hive Mind completely. Within its shadow, lesser creatures bow in servitude, and larger Tyranids find greater access to the warp. It's armored shell protects it from the most powerful weaponry. Any enemy foolish enough to close with it will find no mercy, as it's claws and teeth rip through flesh and armor plating with ease, and within its massive body lie all manner of symbiotic organisms willing to defend their host.
The Karkanos is a lumbering, living fortress. Upon it's back, smaller Tyranids will gather for protection, waiting for the opportune moment to strike at their foes. Bristling with weapons, it can decimate foes as they close, while it's passengers target other enemies.
This multi-part plastic boxed set contains 84 components with which to build one Tyranid Dominar or one Karkanos. This kit contains all the weapon options available to the either creature including cluster spines, heavy venom cannons, brain leech devourers, and acid spray. This kit contains one Large Oval base. It is supplied unpainted and requires assembly - we recommend using Citadel Plastic Glue and Citadel Paints."
"The dominar has a 18" synapse range and Shadow in the Warp range, and increases the psyker level of all Tyranid Psykers within 6" by 1 level. Also has It will Not Die, psychic Monstrosity, IC(c) and can take most Tyranid Biomorphs. It's bigger than the Tyrranofex model, wider with a taller stance, huge head with a massive brain under a wide plate, large mouth like the trygons. It has three rows of vents along the back plates, but the back plates come up behind the head like a turtle, offering protection."
" the Karkanos looks like a crab. It has a wide flat body, the back plate is sunk in and has a ridge around the outer edges. It's front set of arms can hold a few weapon options like venom cannons or devourers or can take claws or talons. Transport capacity is identical to the spore, but it cannot carry MCs. It is a dedicated transport option for the walking troops: warriors, Genestealers, hormigaunts, Termagants. Open top. Has special rules to handle being a MC and transport...not a vehicle. It's probably one of the most expensive dedicated transports in the game. Can be taken in heavy section solo."
und via faeit 212
current GW managerial chart says that's Smaug wasn't good enough for the studio, so GW have had to go back to the drawing board, moving current releases forward so they don't miss the Christmas release window, Nids moving up to Dec, dwarfs in Jan 2014.
06.11.2013 via BolS
Rumor rating: Probable, coming from known good sources
Look for a return of many biomorphs in a big way, led by available model options.
Several plastic models had access to many biomorphs with modeling options in 4th, and those parts are currently cosmetic.
The feeling is that the biomorph options were curtailed much too strongly in the current book and if there is a modeling option for it in a plastic kit, it will have rules in the next codex. I'm looking at you Carnifex (and others)!
und via faeit212
"Rippers are getting a small box like the nurglings. 3 bases. Wings included for sky slashers. Different mouth parts for weapon options."
07.11.2013 via faeit212
New Plastic Hive Guard: Not a dual kit with Tyrant guard - the box just contains 3 hive guard
There is another ranged weapon option for Hive Guard that looks like a spike with 3 talons on the end of it.
08.11.2013 erste Bilder
09.11.2013 via faeit 212 Falsche Info!
via anonymous sources on Faeit 212
the info hes recieving from distributors and GW is that tyranids are being shipped for Dec 7th release.
Just got the confirmation of tyranids for dec!
und
via a strong source here on Faeit 212 from back in August
2 HQ
6 Troops
3 Elites
3 Fast Attack
3 Heavy Support
1 HQ
1 Elite
1 Fast Attack
1 Heavy Support.
25.11.2013 Teilweise Falsche Info!
So nach einem wilden Wochenende mit jeder Menege hin und her - Tyraniden kommen Dezember... nein doch erst Januar gibt es ein neues Gerücht das für die Releases des Jahres 2013 unwahrscheinlich klingt. Allerdings ist es ein neues Gerücht also rein damit 🙂
26.11.2013 Anpassung der Gerüchte, da ja jetzt die Produktliste für den Dezember bekannt ist.
via an anonymous source on Faeit 212 ****
Falsche Info!
December Releases, Tyranids and 40k Expansions
Tyranids are getting 2 boxes (3 total units) dec 16th ish.
These are for current codex models.
New codex in Jan along with new models.
Every (non special character) unit will have a box as of jan
December's release schedule is looking something like this.
December
-Escalation
-Stronghold Assault
-Sigmar's Blood
-Hobbit Releases
Falsche Info!
Mid Month Releases
2 Tyranid Kits and at the end of the month pre-orders for Tyranids
There is a lot of information on what these releases will be. Escalation of course will bring Superheavies and Gargantuan creatures into regular 40k, and Stronghold Assault comes with new fortifications. Here are a couple links if you do not remember what these are.
Escalation- http://natfka.blogspot.com/2013/11/escalation-and-lords-of-war.html
Stronghold Assault-http://natfka.blogspot.com/2013/11/stronghold-assault-and-its.html
Via faeit212
Produktliste Dezember
More old stuff
07.12.2013 Erstes Bild neue Tyranidenkrieger ?!
http://www.gw-fanworld.net/attachment.php?attachmentid=192568&d=1386420645
08.12.2013 via BolS
We rate this set of rumors probable, coming from known sources.
Author: Adam Troke
MINIS
New Tyranid plastic kits:
Warrior - Shrike: 3 model kit.
HiveGuard - Tyrantguard: 3 model kit. New weapon option for Hiveguard, Full lash whip-sword-claw-talon bits for Tyrant guard.
Pyrovore - Biovore - Hellevore: 1 model plastic kit. 3 plastic spore mines included.
Harpy - Eriyne: 1 model plastic kit.
Mycetic Spore: 1 model plastic kit.
Tyranid Prime: 1 model plastic kit.
RULES
Termagant
Troops FOC
Unit size up to 30
Cost: 4pt
Default comes with Fleshborer
Upgrades:
Fleet for 1pt per model
+1 pt Spike Rifles
+2 pt Spinefists (now Assault x(minimum of 2) Twinlinked)
+4 pt Devourers
1 per 10 can take:
+10 pt Strangleweb
+15 pt Electroshock Spitter (S4 AP6 Template Assault 1)
+1 Adrenal Glands - Fleet and Furious Charge
+1 Toxin sacs - Poison (affects cc attacks)
+2 Toxic grubs - Poison (affects ranged fire)
09.12.2013 via BolS
We rate this set of rumors possible, coming from mixed sources.
Tyranid Warriors
Tyranid Warriors available in both HQ (Tyranid Prime)and Troops.
- HQ Warriors function as the Prime's retinue, and do not deploy separately.
- Prime + Retinue may deploy in a Mycetic Spore.
Troops Warriors are mostly unchanged.
Updated Biomorphs.
Adrenal Glands is much improved.
Warriors cheaper in points. (75pts base for unit).​
Harpy-Eirnye
- Arm design is similar to the Forgeworld Harridan.
- Wings attach to the body via 2 sets of arm slots.
- Back 2 pairs are for the wings.
- First pair of arms is reserved for various weaponry/gribblies.
09.12.2013 Solide Gerüchte via Terrorfex von GWF
ALoah Leute,
Hier gibt's mal was neues aus der "solide Gerüchte" Sektion. Ich habe heute mehr oder weniger die 100%ige Bestätigung der Tyras bekommen. Ich war heute bei meinem Einzelhändler under hat heute unter anderem noch bei GW bestellen müssen.
Quellen und Gesprächszensur wegen GW na ja was solls
Zusammengefasste Info:
Tyras im Januar
Harpyie für 62,50
Schwarmwachen für 45,50
Haruspex für 57,50
Krieger Box für 45,50.
Via faeit212
Please remember that these are rumors. Endobai starts off referring to the rumors that we had over the weekend from Bols. If you are curious you can find them listed here by following the link.
http://natfka.blogspot.com/2013/12/tyranids-rumors-are-hitting.html
via Endobai on Warseer
(regarding the Bols rumors over the weekend)
Yep, that is a good idea. Half of it is completely wrong, mistaken or just slightly off the mark.
But hell, there could be a second wave so untill the codex is there it is not certain.
Can't say if the rules are, though - again as long as the codex is not released.
what the hell, expect a dataslate with the release. Nothing unexpected something like this appears I realise, but it will apparently give another option to create an army.
3rd edition players will notice some similarity between it and one evil, sickly powerful army list from a decade ago; though I seriously hope it will be only representing similar idea, but without the rules almost every non-Tyranid player hated back then.
(Regarding the dataslate)
Different name, different rules (I hope!), but in general similar thought behind it. A formation from models in the codex, so not an entire army.
I cannot confirm it fully because too many people will get too exited leading to another 5 pages of discussion on DakkaDakka (cheers guys!) and it will be much less than they will hope for. A nice, (hopefully) flavourish addition, but not the Mycetic Swarm people hated/loved in early 2000s.
(Who is the author of the Tyranid codex)
Ok, that is easy and spoils nothing. No author named.
Apparently right now it is a work of the entire team, but no real suprise here either with rumours about shared work circulating for a while.
Anyway I fully expect some images in next 6 days. As usual first probably something blurry, made by an old mobile phone camera from a wrong angle so that people can discuss how utterly ugly it is and they will never buy it.
I dislike one release from the Tyranid wave, but the rest seems fine or better than fine.
And the cover of the codex is all right, though could probably be better.
The data slate- when I read up on the original Mycetic spore list I think it was more just the deployment type of it- plus it was cool as it represented a specific stage of a tyrannid invasion- so good flavour fluff wise but I wouldn't want anything overpowered - it's just not fun to fight against.
The early invasion theme is still here, but this time without "drop a brood of Genestealers on their heads and see them kill everybody" mode.
Tyranids have their own psyker discipline containing 6 powers, with no access to any of the normal disciplines out of the rulebook.
Langsam wird es schwer hinterher zu kommen so vieles strömt von allen Seiten in die Gerüchtekammer. Einiges war auch schon zu lesen weswegen es hier nicht noch einmal steht. Einfach in den Spoiler schauen. Und ja auch jetzr fangen unterschiedliche Gerüchtequellen an sich zu widersprechen 😉.
10.12.2013 via faeit 212
Please remember that these are rumors. This is all rather reliable bits of information. Discuss away.
via 4chan.
Pictures from WD will be tommorow.
Psychic Powers table: Dominion (Primaris), Psychic Scream, Warp Blast, Catalyst, Paroxysm, the Horror, Onslaught
Warriors + Prime bits (not a word about wings in a box)
Harpy + Something
Something Hungry + Something Shooty
Hive Guard + Other Known Guard
via daboarder on Bols in response to above.
ok guess I can give more info now this has dropped.
Those powers haven't changed........
yup how ****ty is that, can you imagin rolling the horror? bleah!
and zoans no longer have a base shooting power
oh and no, things without models are NOT in this codex (dont know about shrikes given the FW kit) but special character that was popular with 3rd party sculptors is dead and gone.....
Cue the cries of "the DoM was cheese anyway".....ya know, despite shriek being a primaris power for telepathy.
via BolS
Psychic Details
Tyranid psykers generate psychic powers in a new way. They gain 1 warp charge from each synapse creature within 6" but each synapse creature only generates a single warp charge. Tyranid psykers additionally gain a single warp charge per mastery level. This rule mechanic depicts the ability of the Tyranid Hivemind to focus power to key psychic organisms via the synaptic network. Each psychic organism however does have a maximum amount of warp charges it may utilize in a single turn, to prevent abusive "machine gun use of powers".
Apparently units of multiple synapse creatures now have another useful purpose - psychic reservoir.
There is also contradictory chatter on whether or not the new Tyranid psychic powers will replace the rulebook powers entirely. Some say yes, some say no.
-Dominion (Primaris)
-Psychic Scream
-Warp Blast
-Catalyst
-Paroxysm
-The Horror
-Onslaught
Units Rumors
Various tongues are wagging that one of the new big bugs is the old EPIC chesnut, the Haruspex. Not only that, but the Haruspex is only one half of a combo kit and yet another EPIC big bug is buildable from the kit. ~PS, there's really not that many left... go looking.
Broodlord comes with fixed psychic power and a large number of biomorph options.
There is suddenly a distinct number of rumormongers talking about the removal of the Mycetic Spore and any other unit without a model in the codex (you do the math). Some chatter says the rumored Dedicated Transport big bug may replace it entirely as it never received a model in the first place.
via faeit212
Please remember that these are all considered rumors, although Endobai seems to be right on top of what is going on right now.
I had to find the Tyranid codex and more important had to work for a couple of hours, too addicted to things such was food, drink and shelter to ignore this need. I am no Tyranid player so I wanted to have the codex in sight not to make any mistakes people will in turn mistake for something else.
It is still too early to say too much - hardly enjoyable to be in the spotlight shining like the Astronomican for the Hive Fleets...
I can only say maybe 20% of what I know for now. Soon images should start appearing in the web so it will be possible to comment on some of them.
Warriors.
In my opinion definetely the centerpiece of the release. Much like the Tactical squad for the Marine codex they are something every Tyranid player - new or veteran - will have to buy.
The box includes all or almost all weapon options the Warrior entry in the current (still the current) codex has + something really nice. Still don't expect all your wishes to come true. Remember it is no more than three infantry sprues in the box.
The unit's cost.
It depends on the cost of wargear and what special rules give them - namely what Synapse Creature gives them in the new codex. Right now I can see no meaningful point decrease. Still troops though.
Tervigon.
Still troops, but comes with 'the Gaunt tax' to occupy the slot. Gaunts are cheaper so it helps a little.
Much depends on the new psychic powers the Tyranids get because it remains a psycher with randomly generated powers so unlike some psychers in the new tyranid codex.
The Big Bug.
It is big, but not that big. Remember that the Wraithknight and Eldar models in general are smooth and do not have so many limbs, vents, horns, bio-guns etc so making something as large as the Eldar fellow would create something really, really expensive - definetely in titan price range. The big bug is thankfully cheaper.
The creature is taken from the Epic 40k, but the difference in size is not so ridiculously... pronounced, but it is large enough.
Ohh and the instinctive behaviour list is expanded - with entirely new modes some creatures will take when separated from the Hive Mind.
Tyrant Guard too got something new, a weapon upgrade they will find really useful.
The poster below was spot on. The Warriors are a new set, the last one was from 2001 so it is as with the Tacticals who got reinvented, multi-optional new sprues. Cool, useful, but they are not super-killy. Can easily be made the core of the army and have access to very many weapon options so good value for money too.
Psychic powers.
I doubt they will remove the access, so far nothing suggests it.
I can safely say something more.
All those sets allow construction of another unit, also the Haruspex which can be assembled as... another creature from Epic 40k.
Hive Guards got another weapon option which can be seen on the leaked image.
The weapon is electricity based. No doubt inspired by Teslas, but I have no idea if it works in a similar way.
Tyrant Guards are very lovely. My most favourite models in the release combining what is the best in the 3rd and 4th metal models.
Several weapon options just like with the warriors.
I think that they got those new 50 mm bases. I was mistaken in the past with the SM Centurions so forgive me if I commit another once again.
Haruspex is damn ugly so you will recognise it immediatelly, but its 'twin' is actually really nice looking MC.
Harpy's 'brother' is not called Eridne/however it was called in those rumours.
Hormagaunts
Cheaper and faster. Think of Slaaneshi Daemons.
Lictors
Of course nothing speaks like autonomous, scout, vanguard creature like a model which after landing realises how alone it is, how scary the world is and that everyone wants to kill it - so I hope it regains at least its autonomy. Rather safe bet in my opinion.
Rippers
If I see it right got more expensive, but are no longer suicidal.
Releases
Dual sets (one, lets say, is half-dual), so four MCs including three new beasties.
There are also other boxes, but re-packs/army sets.
No clamshell.
11.12.2013 via faeit 212
via an anonymous source on Faeit 212 (vermutliche €Preise von mir)
New Releases January 11th
Codex Tyranids: by the Games Workshop Design Studio $49.5 £30 ~ 39€
Tyranid Psychic Cards $6 £3.5 ~ 6€
Tyranid Harpy/ Hive Crone $80 £48 ~ 62€
Tyranid Haruspex/ Exocrine $73 £44 ~ 59€
Tyranid Warriors (3 models) $51 £31 ~ 46€
Tyranid Hive Guard/ Tyrant Guard (3 models) $70 £42.5 ~ 45€
Carnifex Brood (2 models) $90 £55 ~ 65 - 70 €
Tyranid Swarm (95 models) $170 £105 ~ 130€
yranid Limited Edition Codex $100 £60 ~ 90€
Tyranid Termagant Brood (20 models-online only) $33 £20 ~ 25€
Tyranid Hormagaunt Brood (20 models-online only) $33 £20 ~ 25€
BILDER via 40kwarzone & unbekannt imgur
via faeit212
via an anonymous source from the Faeit 212 inbox.
Ive seen the cover, and its a tyranid warrior screaming with a backdrop of a full fledged tyranid invasion behind him with domes covered in large protruding spikes.
Of course the codex comes with Warlord Traits, new bioartefacts, and new instinctive behavior charts.
The enhanced ipad version has its own Force Requisition and includes audio tracks that I am not sure the Space Marine codex had.
Man man man, bei der Gerüchte Schlagzahl kommt man ja gar nicht mehr hinterher!! Also weiter gehts gelegentlich ohne Quelle weil direkt aus diesem Thread :huh:🙄.
via 40kings
Bilder
http://www.40kings.de/2013/12/update-mehr-infos-tyraniden/
Swarmlord – 285pts
Tyrant Guard (Scything Talons, Crushing Claws) – 70pts
Tervigon (Crushing Claws, 1 power) – 210pts
Hive Tyrant (2x TL Brainleech Devourer, wings, 2 powers) – 230pts
Hive Tyrant (Heavy Venom Cannon, 2 powers) – 185pts
Venomthrope – 45pts
Hive Crone – 155pts
Harpy (TL Stranglethorn) – 135pts
Trygon Prime 230pts
Exorcine 170 pts (Bio-plasma, large cake or 6 shots s7ap2)
3 Carnifexes (2x 2TL brainlech Devourers, 1x Stranglethorn) – 435pts
Tyrannofex (Rupture Cannon) – 205pts
Tervigons
- Purchasing a single 30-model Termigant unit unlocks Tervigons as TROOPS choice.
Tervigon upgrades include:
20pts – enlarged spawns roll 4d6.
15pts – unlimited spawns, never “burn out”
Both upgrades can be purchased
Army Special Rules
Synapse providing Eternal Warrior.
via Xentar
Laut BoLS Carnifex ca. 120 Pkt. nackt ohne Alles, ABER höchstwahrscheinlich W6. Tyrannofex W7 und 2+. Außerdem wird dort diskutiert, dass der neue Tyra Flieger wohl der neue Heldrake werden soll, S8 Vector Strike + Flamer-Template Waffe + lebendige Raketen. Schwarmtyranten overall auch deutlich günstiger als vorher. Gargoyles Standard, Tervigon-Upgrades laut jemandem der den WD hat fake.
Massiver Punktedrop beim Tyrannofex, man redet von 60 Pkt. weniger.
Psychic Powers:
Primaris: Dominion, blessing, +6" synapse range for the caster
Catalyst - FnP for caster and unit, and another unit in 12"
Paroxysm
the Horror - Broodlord have this power
Onslaught
5. Psychic Scream - 1 charge, nova 6", each target takes 2d6+2 minus its Ld wounds without covers and armors
6. Warp Blast - 2charges, witchfire, unchanged
Bounding Leap on Hormagaunts is explained there and it gives +3" Run.
Limiting Tyranids for codex-only powers is also NOT mentioned in the magazine,
Shadow in the Warp - not much about this, because it is useless against enemy in BatRep.
Which is Tau with 6 Riptides.
Old One Eye in the report is regenerating like crazy.©
Read more: http://thetyranidhive.proboards.com/...#ixzz2nB69pII9
1. Synapse gives eternal warrior
2. Gargoyles are troops.
3. Trygons (primes), Carnifex, Hive Tyrant, Tyrannofex, Venomthropes have significant point decreases
4. Zoanthropes come with Psychic Scream, and warp blast as standard
5. Brain leach devourers no longer strength 6
6. The Crone has a massive vector strike
7. Tervigon, Warriors, gene stealers have significant price increases
8. No Doom, Parasite, Spore pod.
9. The big cannon bug has two different firing modes, one being a D3 Large Blast and one being multiple high strength, low AP shooting attacks.
10. Hungry eyes bug has the ability to magna grapple vehicles and enemy troops.
via unerde
That Termagant Brood entry states:
- Unit size of 10-30, 4pt/model, statline unchanged
- Move Through cover and Instincitive Behaviour (Lurk)
- Comes standard with a fleshborer, and any model may replace their weapon for spine fists or a spikerifle for free, or a devourer for 4 pts, and 1 per 10 gants may take a splinterweb for 3pts.
- Adrenal glands and toxin sacs for 2 pts/model each
- For every Termagant Brood of 30 models, you may take 1 Tervigon as a Troops choice
http://thetyranidhive.proboards.com/...efined&page=52
12.12.2013 via faeit212
Warrior kits come with 3 models, one of which can be upgraded to a Tyranid Prime. The Tryanid Prime parts include a new chestpiece, flared shoulders, and a new head. The box also comes with all the options you can take, meaning everything is included.
Lash whips, boneswords, sything talons, and rending claws to outfit all three models, with bioweaponry like spinefists, devourers, and deathspitters. One model per brood can take heavier weapons that are included in the kit, such as the barbed strangler and venom cannon.
Options include toxin sacs, flesh hooks, adrenal glands
Warriors are now BS5
With the dam broken I am satisfied with my work and can use recently gained (un)deserved fame and glory for the benefit of humanity elsewhere.
I'll start with the benefit of one human, namely myself - which unfortunatelly takes time and effort.
Since I cannot afford answering all the PMs (sorry guys, but a dozen? Have mercy.) I will go through this single post.
You must understand that disproving fakes sometimes takes more time than writing something, even in enigmatic (living in the city where the Enigma was broken helped) Alpha Legion/Eldar style.
I am not a Tyranind player and each time I have to check the (still) current Tyranid codex to see if I make a mistake which would no doubt haunt me for the eternity in the endless depths of the Internet.
Recent rumours, most likely from 4chan are mostly valid, but there are fakes coming from more... creative sources.
Some might be still spot on, so I will only discuss those things I can confirm or deny easily.
Endobai responses are bold italics
Not proven yet.
Seems a good deduction considering the price of the Warriors which remains more or less unchanged, but so far I have no solid confirmation.
Cannot confirm that. FOC changes via HQs are possible, but right now just a speculation.
True. Values are posted elsewhere, cannot tell if all are accurate, but in general there is a point decrease.
Nothing supporting this. I said some creatures are assigned specific powers and in this case it is a prime candidate, but right now I cannot say a definitive yes.
Don't remember, but both are quite likely.
Warriors and Genes stay the same, upgrades are either cheaper or more expensive, but the basic cost is identical.
Tervigon is more expensive, by about a nude Warrior cost.
Cannot say for sure, but no confirmation they are and no traces of their presence I could find.
Have no idea why it is supposedly D3. One concentated large blast with Ap2 and S7 or six lesser shots (six barrels).
BTW
Interesting bit. The gun is the brain of the creature, the grinning imbecile below is just the muscle useful to allow the brain to calculate all those things it likes and no doubt design subtle works of surreal art from the splattered remains of the enemy. Think Master-Blaster from 'Mad Max 3'.
Nice, but pure speculation so far.
Psychic powers
Don't remember.
True.
True.
Don't remember.
Will have access to BRB powers.
No reason to disprove it now or earlier.
Codexcover!!!
http://40kwarzone.blogspot.ae/search/label/Rumours
via TheKingYellow von warseer
Genestealers:
Same point cost, no change in stats/abilities.
Broodlord seems to have The Horror as a fixed psychic power
Adrenal Glands one point less
Toxin Sacs unchanged
Scything Talons at double the old points
Warriors:
Same point cost, no change in stats.
Still have Synapse and SitW
Adrenal Glands unchanged
Toxin Sacs at 2 points less
Flesh Hooks at the old Toxin Sacs points
Allowed to take weapons from 3 lists (not yet seen):
Melee bio-weapons
Basic bio-weapons
Basic bio-cannons
The latter appears to be only 1 per unit, rather than 1 per 3 models.
Of interest, the Warriors have the "Very Bulky" rule. Why would that be included unless there was a transport
Rumour is the the Haruspex has a 20pt upgrade that allows you to transport 20 models, so 5 warriors + a Prime. If it's an assault transport, look out!
13.12.2013 via BolS
Point Costs
Exocrine is costed as a Keeper of Secrets
Crone is costed as a Daemon Prince of Slaanesh
Venomthrope: 10pts cheaper
Trygon Prime: 10pts cheaper
Hive Tyrant: 15pts cheaper
Harpy: 25pt cheaper
Carnifex: 40pts cheaper
Tyrannofex: 60pts cheaper
Tyrant Guard: @same
Tyranid Warriors: @same
Genestealers: @same
Ripper Swarm: 3 pts more
Swarmlord: 5pts more
Tervigon: 15pts more
Tyranid Warriors Kit
3 model kit
Tyranid Prime bits included
Boneswords
Lash Whips
Rending Claws
Scything Talons
Barbed Strangler (1)
Deathspitters
Devourers
Spinefists
Venom Cannon (1)
via L'Astropate
via faeit212
Please remember that these are rumors, some salt is always required. Previous rumors has the box set at $90 or £55. Of course the release date is still on January 11th with advanced orders going live January 4th.
The new box makes two carnifexes with all the new options included.
Parts to make Old One Eye or your own beast or version of him are included
One kit makes up both the Harpy and the Hive Crone
The model is larger than any other flyer we have for from GW
The Harpy can be labelled as a bomber and comes with a stranglethorn cannon or heavy venom cannon, and can drop biological spore bombs (3 choices).
The Hive Crone is meant to take on air targets with its claws, and comes with drool cannon, that spits digestive acid onto its foes. On the bottom of the wings the Hive Crone comes with 4 tentaclides (missiles) that are used to take down aircraft.
I know everyone saw the leaked images of the Hive Guard, and I want to confirm that it is a dual kit making either Hive Guard or Tyrant Guard. The other weapon in the leaked pictures besides the Impaler Cannons, is a Shock Cannon. The kit allows you to equip all three with either weapon.
As far as the Tyrant Guard are concerned, all options are included like most 6th edition boxes, from scything talons, crushing claws, lash whips and boneswords.
Again advanced orders are not coming until January 4th. Release date is the 11th.
14.12.2013 via faeit212
The new Tyranid Swarm box set has 95 models and includes a good cost savings for buying this set.
It includes:
40 Termagaunts
40 Hormagaunts
10 Gargoyles
1 Carnifex-with the options for One Eye
4 Ripper Swarms
18.12.2013 via BolS
Crone
155 Pts
S:8 Vector Strike 4x S:7 AP:2 shots from the mouth gun, OR a large blast!
155
4x air-to-air bio-missiles
Tyranid Biomorphs
Unique Biomorphs (one per army)
-"Uber-Synapse": An HQ only biomorph that has a reduced radius for synapse, but grants Eternal Warrior to bugs within it.
"Uber Carapace" Armor Save 2+, Eternal Warrior on non flying creature.
-"Uber-Boneswords": Hive Tyranids/ Tyranid Primes only: AP:2 and heals the user a lost wound for each wound inflicted on a 5+ For Primes and Tyrants. Regular boneswords are AP3 by the way.
-"Bio-flamer": Hive Tyrants/Tervigonso nly, Template, AP:3
-"Spore Barrage": Poison 3+, Large blast, Ordinance, Remains in play, Range:Unlimited, One-use only
19.12.2013 via dakkadakka
Bilder Codexseiten recht weit oben:
Bilder Tyrantenwache erster Post unten:
via forofreakfactory
Hormaganten und Ripper Codexeintrag:
27.12.2013 via dakkadakka
via Tyran on Dakka Dakka
I just have a nice chat with a player in Vassal.
He supposedly got to see the new codex in a veterans tour at Warhammer World.
Rumors:
Tyranids can't take fortifications, but have +1 HQ, +1 Elites, +2 Troops, +1FA and +1 HS
Tyranids are going to have 3 supplements: Leviathan, Kraken, and Jormungandr. It is going to be a swarmy one, a nydzilla one and an infiltration one. But GW hasn't started to write them yet so anything may come.
There are advanced, basic, experimental, etc biomorphs.
Shadow in the Warp is a 12" bubble of -4 ld for enemy psych test, but also grants units the 5+ to deny.
No way to make Warriors viable, according to him the Eternal Warrior rumors are wrong.
Toxins Sacs may be the same, according to him the wording was poison 4+ to the attacks, not making any distinction between CC and ranged.
Flesh Hooks are assault grenades and d6 S6 ap5 rending and precision shoots.
Adrenals Glands give Furious Charge and the +3" run.
Scything Talons give an additional attack.
No Doom of Malan'tai, Parasite and Mycetic Spores.
Regeneration gives IWND.
Catalyst gives +1 to FNP and IWND.
Venom Cannon is S9 ap4 2 shots.
Deathspitter is back to being a blast.
Barbed Strangler is st6 ap5 and must take a S test or take d6 st4 ap3 hits.
Stranglethorn Cannon is the same but S8 and pinning.
Acid, explosive and poison spore mines are back.
Any Prime unit can be HQ, this includes Warrior Prime, Trygon Prime and Old One Eye.
Only 1 Psych Powers chart.
Carnifex:
120 points
Got a new page of upgrades.
2+ save for 15 points
1d3 Hammer of Wrath attacks
Can attack the occupants of a transport after destroying it in CC.
Harpy:
140 points
Fast Attack unit
WS 4 BS 3 S 7 T 5 W 4 I 5 A 3 LD 8 sv 4+
Sonic Shriek is when it flies over unit.
Also carries spore mines
Born in the Skies: Can't be grounded
Crone:
170 points
Fast Attack unit
WS 3 BS 3 S 8 T 5 W 5 I 5 A 3 LD 8 sv 3+
4 S7 ap2 shoots or 1 S7 ap2 large blast
Missiles
"Haruspex":
Elite unit
"Magna Graple" attack
WS 4 BS 3 S 8(or 9, he wasn't sure) T 6 W 5 I 4 A 5 LD 8 sv 3+
"Exocrine":
Heavy Support unit
3 S10 ap3 shoots or 1 S10 ap2 large blast ordnance
WS 4 BS 3 S 8(or 9, he wasn't sure) T 6 W 5 I 4 A 3 LD 8 sv 3+
Tyrannofex:
180 points
Rupture Cannon cost 20 points
Old One Eye:
300 points
It is an upgrade for a Carnifex brood, but it also can be an HQ option
4+ IWND
3+ FNP
2+ Save
Hive Tyrant:
160 points
BS4
Wings for 30 points
Mastery Level 2
Tervigon:
170 points
Mastery Level 2
Can take 1 of 3 upgrades for spawn: 4d6 spawn, or the no run out for doubles, or all gaunts (note that it includes Termas, Hormas and Gargoyles) benefit from Toxin sacs and Adrenal Glands
Also you can customize the spawn options for a cost, for example spawning hormagaunts or spinegaunts
Lictor:
Shrouded and Stealth
Doesn't scatter
Deathleaper:
All attacks are precision
Keeps the 5+ rending
Trygon:
6+2 (from Scything Talons) attacks, Initiative 5, WS 5
Bio electric field: 6 S6 ap5 shoots or a 5++ invulnerable save
Trygon Prime:
Gaping Maw experimental biomorph: If half or more of the attacks hit, a random model in b2b takes an Initiative test, if fails it is removed from play. According to him it has no limitations, so it can eliminate a Riptide or anything else.
Mawlocs:
140 points
1d3 blast with the ignores cover rule for its attack from below
Tyrant Guard:
Broods of 1-5
Lots of options
Hive Guard:
New gun is Spike Cannon, S7 ap4 2 shoots with Skyfire, enemy must reroll successful grounding tests
Gargoyles:
5 points
Fast Attack unit
Lost Blinding Venom
Hormagaunts:
5 points
Bounding Leap is charge after running
Swarmlord:
Mastery Level 3
Zoanthropes:
Mastery level 1, but generates 2 warp charges (for Warp Blast)
Venomthropes;
30 points:
Grants shrouded and defensive grenades in a 6" radius
28.12.2013 via warseer
I'll temporary leave my cave to comment on those.
personally I'd expect something accurate in the coming week i.e. something this pile of text is not.
Second looks like wishlist. Cannot imagine 9 Tyranid Warriors throwing 9d6 precision shots - can you?
Opposes all what we know for example about Horms = disproven.
Unless there are different effects for monstrous creatures and such and different for little fellas,
Harpy:
140 points
Cheaper.
Fast Attack unit
Yes.
Yes.
No idea.
Crone:
170 points
Cheaper.
Fast Attack unit
Yes.
"Exocrine":
Heavy Support unit
Nope. Six small shots, one large, but not that strong.
Hive Guard:
From the description of the weapon I doubt it can be skyfire. The weapon, but it doesn't mean that the unit will not be able to from its basic gun.
Lost Blinding Venom
No, still have it.
Hormagaunts:
5 points
No it is not.
Swarmlord:
Mastery Level 3
Yep, what I said before.
Venomthropes;
30 points:
Nope. Add quite much to the cost - about the cost of a Marine.
I know nothing much above what we already know by this point, but clears some air.
30.12.2013 via faeit212 Limited ED Cover
via chunk on the Tyranid Hive
http://thetyranidhive.proboards.com/thread/44428/tyranid-rumours-dec-29?page=107
the new Limited Edition cover, end page, and dust jacket.
People have pointed out they're all recolours of existing artwork, so sprinkle some salt onto these pictures.
Extra Details on the Limited Edition Tyranid codex
The leaked artwork for the limited edition are real. They are Raymond Swanland's artwork
2,000 copies worldwide
the reverse inside is a full wrap around battle of Tyranids fighting Orks by artist Paul Dainton. The scene is epic as a full on Tyranid invasion full of Hive Crones and swarms as they overrun the Orks.
via Games Workshop 😉
31.12.2013 via faeit212
There are a lot of picture leaks now running around of the January White Dwarf. You can see the new box releases, and pictures of the new models in the lineup.
Of course we have seen the information presented in these pictures, but its nice to go over and check them out.
We are only a few days out now from the actual release now of the White Dwarf and pre-orders going live for Tyranids. Here are two different links to the pics that are out there.
http://descansodelescriba.blogspot.com/2013/12/precios-en-euros-de-los-tiranidos-desde.html
http://www.akibastation.es/2013/12/wargames-scans-de-la-white-dwarf-de.html
02.01.2014 via Totenfrost von der GW-FW
Hab nix auf der erste Seite gefunden, deswegen in der 20er Termaganten-Rotte sind 3 Absorberschwärme dabei und Warplanze wurde geschwächt, hat laut Psikarte nur noch Ds2.
via faeit212
via Terrorfex over on Warpshadow
To all Brothers: i have a very very riable Source which gave the Following Infos. I wont endanger my Source but i can Tell You this ins 99% true:
Shadow is 12 Inches -3 LD for psi
Hive crone is Vector Strike 8
Missiles are rerollable S5 pulse
Exocrine is bs3(4) t6 w5 3+
24 Inches, S7 ap2 6 shots or lagre blast
Bs4 when stationary
Haruspex ist t6 w5 3+
Gains an Attack for Every lost wound
Heals One wound for Every unsaved wound caused
ACHTUNG VIDEO ENTHÄLT DEN JANUAR WHITE DWARF!!!
Wer das selber Blättern will besser nicht ansehen hab ich auch nicht über Sec. 5 hinaus gemacht.
Wegen rechtlicher Fragwürdigkeit gibts erst mal nur den link. unerde hats gefunden.
07.01.2013 via faeit212
via Sinsigel over on Warseer
I bought the new tyranid codex to share it with my fellow gamers yesterday.
Pyrovore remains largley unchanged save that it gets slight boost to wounds, attacks and initiative.
Its cost is slightly reduced while acid maw attack is given at a bit higher strength but at the cost of making only single attack.
Mawlocs and trygon both are cheaper. Mawloc especially is about 20~25% cheaper.
Mawloc's special rule Terror from the Deep is still much same......except that when the damage is resolved hiding in ruin or cover of other kind is literally useless.
Mawloc can also resolve damage(via Terror from the Deep) more than once if there isn't enough space.
Shadow in the Warp gives penalty to nearby enemy psykers' leadership.
Harpy is also cheaper. Its wounds and attacks are slightly boosted.
Carnifex and tyrannofex both became considerably cheaper. Around 25~30 percent or so.
Carnifex can still take devourer with brainleech worms which remains same as before.(Just without its penalty to enemy leadership)
It has less attacks and slightly higher initiative, but it can inflict more than one Hammer of Wrath hits.
Both types of gaunts became slightly cheaper albeit the upgrades are bit more expensive.
Zoanthropes are also cheaper.
And as forementioned in my previous replies, impaler cannons will be the bane of eldar wave serpents if they come within range.
As for biomorphs, crushing claws are changed in a way that they don't give extra attacks but are more effective against vehicles plus strength buff.
Regeneration probability became much higher.
Tentaclids and electroshock grubs are effective against vehicles(Bionic EMP I suppose)
Other than some boosted version of already existing shooting attack, I see no significant difference.
Taking account of its crushing claws, Haruspex has decent strength(stronger than mawloc, weaker than carnifex) with small number of attacks.
It however can increase its attacks depending on how many wounds it suffered, while at the same time can regain the wounds.
Its blood is also acid while its tongue attack can pierce terminator armour.
Boneswords inflict Instant Death depending on to-wound roll while lash whip boosts wielder's initiative.
Warlord traits include buff to synapse range, reducing cover, turning a forest into more carnivorous one, etc.
Psychic powers include another buff to synapse range, FNP, pinning test with additional leadership modifier, pseudo-psychic shriek etc.
Last thing. Malantai is NOT destroyed by a single zoanthrope.
And no more steel rain for tyranids.
via singsel von warseer
Some infos again.
Synapse Creature : 12" Fearless and auto-regroup
Adrenalin Gland : Furious Charge and Fleet
Toxic Sacs : poisoned CC
Lictors : Now have infiltrate but without bonus to reserve rolls. About 20% pts drop
Deathleaper : Slight pts reduction, Changed to HQ. Has warlord traits giving additional VP when wins challenge.
No fearless but gained infiltrate. Enemies can only shoot snap shots against it and it still give penalty to enemy leadership.
No what was that and where'd it go
Tail weapons : CC weapon. Four kinds
1) S8, AP-
2) S6, AP5
3) Poisoned
4) S4 AP4 Rending
Ravener : Slightly less attack. No acute senses and no move through cover
May take expensive champion upgrade which can remove infantry model in b2b if all attacks hit.
Some of the psychics are : -D3 to WS and BS ; Allows friendly unit to run and shoot
Rending Claws have AP value of bolter. And No ymgarls
Hive tyrant can still give outflank to one troop unit by purchasing extra upgrade. Can only use tyranid psychics. So no biomancy
Flesh hook without rending
No 2+ armour for carnifexes. Although tyrants, tervigon and trygon can take it via bio-artifacts.(See below)
There are few bio-artifacts compared to other codices.
Some of them are : Bonesword with strength buff ; Ymgarl transformation(Which can increase armour save slightly)
Trygon of both kind are bit cheaper at the cost of slightly less attack. The tunnel rule remains largely unchanged
Instictive behaviours are fixed per unit just like former codex.
However, there are three specific results per behaviour depending on dice.
Lurk : Fall Back / Can shoot only when hidden / Can shot only when hidden + Stealth
Hunt : Go to Ground / Shoot closest unit / Shoot closest enemy unit + Preferred Enemy
Feed : Inflicting hits on themselves / Assault closest enemy units / Assualt closest enemy unit + Rage
08.01.2014 via BolS daboarder
Psychic Powers:
NO BRB ACCESS!
Dominion, primaris: blessing, targets psyker, +6" synapse, ML1
Catalyst: Blessing, FNP on caster and unit within 12" ML1
The Horror: Malediction, -2Ld Pinning test on unit within 24" ML1
Onslaught: Blessing, target may run and shoot, 24" ML1
Paroxysm: Maledition, -D3 WS, BS, 24" ML1
Psychic Scream: Nova 6" 2d6+2-Ld wounds, ignore armour, cover ML1
Warp Blast: witchfire
24" S5 Ap3 Blast
18" S10 Ap2 Lance
ML2
RELICS:
Claws: S user, AP5 rending, if bearer kills model in CC gains Preferred enemy (that codex) for the rest of the game
Crown: +6 Synapse range
Cannon:
Two Profiles
36" S1 Ap4 Assault 1, Blast, Poison 2+
Template S1 Ap4 Assault 1 Poison 2+
Ymgarl:
Mechanic same as last codex with
+1S or +1A or +1Sv
Sword
S +1 Ap3 Shred, 6's to wound cause ID, +3 initiative
Biomorphs:
Acid Blood, Enemy unit takes I test for each wound caused by it in CC, if failed take a S(3?) Ap2 hit, ignores cover
Acid Maw: Replace all attacks for single attack with
S5 Ap2 Melee
Blinding venom: Replace all attacks for single attack with
S3 Ap- Poison 6+, Blind
Regeneration: Roll a dice at end of turn if one or more wounds missing, 4+ regain a single wound.
Toxic Miasma: During assault phase, once a game at I1, Enemy units in assault with the tyranid takes a S3 Ap- Poison, ignore cover hit, the number of hits is equal to the number of enemy models in B2B
Flesh Hooks: Assault grenades:
6" S user Ap- assault 2
Spine banks:Assault grenades
8" S3 ap- assault1 blast
Toxin sacs: Poison
Wings: Turns MC's into FMC
Tails: single bonus attack, does not benefit from special rules, biomorphs or any other gear
Bone: S8 Ap- Unwieldly
Pincer: S6 Ap5
Tresher: S4 Ap4
Toxin: S1 Ap6 Poison 2+
Miscelanious
Shadow and synapse are two separate rules
Shrikes:IN
Sky-slashers: IN
Ymgarls: OUT
Fleshhooks on warriors and shrikes
Scytals: NO ADDITIONAL BONUS, S user Ap6 is all she wrote folks.
Haruspex: Regular MC pace
Trygon tunnel: No way to dedicate units to the tunnel
Toxin Sacs :10 pts
Ad glands: 15 pts
Regeneration: 30 pts
Acid Blood: 10 pts (haruspex may not take this)
via tyranidhive Warlord Traits von jackedup
Warlord Traits:
1 - Nature's Bane - At the beginning of each movement phase, select one jungle within 12' of the warlord. It becomes carnivorous for the game.
2 - Heightened Senses - Warlord and Nids within 12' have Night Vision.
3- Synaptic Linchpin - Warlord has 18' synapse
4 - Mind Eater - 2 VP for independents slain by warlord in a challenge.
5 - Digestive Denial - After deployment, pick one piece of terrain on opponent's side that was NOT paid for. Cover save worsens by one. (4+ becomes 5+, etc.)
6 - Adaptive Biology - Warlord gains FNP (5+) on next movement phase after it suffers a wound. (For rest of game)
Ehrlich gesagt versteh ich das Geheule auf Seiten der Ammis nicht. Wie in jedem Codex was gutes und was schlechteres.
Deathspitter 18', Str 5, Ap 5, Assault 3
Zoanthropes are a psychic brotherhood (level 2), that always know warp blast. So they generate one more.
Speaking of which I just noticed: The Tervigon is now 195 points, and is mastery level 1. So its psyker powers got nerfed a bit I think.
The new mechanic in the book is that instinctive behaviour is now lurk, feed, and hunt. Basically lurk means camping there, feed is assault, and hunt is shooting. If you fail leadership and they go on instinct, something bad happens on a 1-3 (lurkers fall back, shooters go to ground, feeders attack one another). On a 4-5 its something like can only assault, can only shoot, etc. On a 6 they gain a small bonus (feeders get rage, lurkers get stealth, shooters get preferred enemy.
The Prime still boosts the warriors as always.
Heavy Venom = 36', Str 9 AP 4, Assault 1 Blast
Venom = 36', Str 6 AP 4, Assault 1 Blast
Ripper Swarm:
39 pts for 3 bases, +13 pts per base
WS 2 BS 2 S 3 T 3 W 3 I 2 A 4 Ld 5 Sv 6+
May take Spinefists, toxin sacs, adrenal glands, and deep strike.
Genestealers come with Rending claws, but yu can buy ST for 4 pts per model
Hormagaunts are Fleet, Move Through cover, and have bounding leap (run +3 inches)
Warriors are 30 points per model (I don't have the old book on me to refer)
Warrior stats are:
WS 5 BS 3 S 4 T 4 W 3 I 4 A 3 Ld 10 Sv 4+
Yes, there are Haywire weapons. The flying Crone has Haywire missles, and the Hive Guard can buy a Haywire "shock cannon". Also, the electroshock Thorax swarm is now Haywire.
The Lictor's Pheromone trail says any model can drop within 6 inches of it when deep striking without scattering (again, don't have the old book here to compare, sorry)
Sieht aus als hätte ich die Wette gewonnen 😉
Zoanthrope Issue - A Zoanthrope brood follows all the rules for Brother hood pf Psykers except that the unit has a Mastery level of 2. In addition, if a brookd of Zoantrhopes uses the Warp Blast power, the number of shots fired is equal to the number of zoanthropes in that brood. (eg 3 Zoanthropes would make the burst and lance profiles assault 3)
Doom is gone, parasite is gone, mycetic spore is gone. Ymgarl stealers are gone, but the "ymgarl factor", of giving a special boost each assault round (+1 Str, +1 atk, Improve armour save by 1), can be purchased as a bio-artefact for 40 points.
Spore mines and shrikes are still around, and Red Terror is back. Gargoyles still have blinding venom, can buy toxin sacs and adrenal glands.
I don't see options to improve the Hive Tyrant's carapace to a 2+ save anymore, or any other HQ's for that matter. Looks like you'll need the Ymgarl Factor.
Tyrannofex rupture cannon is 30 points, 48' range, S 10, AP4, Assault 2
The tail morphs are:
Bone Mace, S 8, AP - , Unwieldy
Prehensile Pincer, S 6, AP 5
Thresher Scythe, S 4, AP 4, Rending
Toxinspike, S 1, AP 6, Poisoned 2+
A tail attack allows a single added attack, resolved separately from a model's other close combat attacks. It doesn't benefit from other melee weapons, biomorphs, etc.
Hive Tyrant stat line:
165 pts, WS 8, BS 4, S 6, T 6, W 4, I 5, A 4, Ld 10, Sv 3+ ( Interesting: You now have to pay 20 points for lash / whip, or it comes with two sets of ST)
FOC as follows:
HQ - Hive Tyrant, Swarmlord, ld One Eye, Tervigon, Tyranid Prime, Deathleaper
Troops - Warrior, Genestealers, Termagants, Hormagaunts, Ripper Swarm
Elites - Hive Guard, Lictor, Zoanthrope, Venomthrope, Haruspex, Pyrovore (Ha ha! Pyrovore "Elite"!)
Fast Attack - Shrikes, Raveners, Red Terror (as part of ONE Ravener brood), Sky Slasher, Gargoyle, Harpy, Hive Crone, Spore Mine Cluster (how mines are "fast" attack is beyond me)
Heavy Support - Carnifex, Biovore, Trygon and Prime, Mawlc, Exocrine, Tyrannofex
Powers of the Hive Mind:
1. Catalyst - 1 charge
Blessing that targets psyker's unit and up to one other friendly within 12'. Targets gain FNP.
2. The Horror - 1 charge
Malediction targeting single enemy unit within 24'. Target takes a pinning test at -2 Ld
3. Onslaught - 1 charge
Blessing that targets a single friendly unit within 24'. Unit can both run and shoot in the shooting phase.
4. Paroxysm - 1 charge
Malediction targeting single enemy unit within 24'. Target's WS and BS reduced by D3 (roll once for both)
Nova power, 6'. For each target unit, roll 2D6+ 2 and subtract Ld. Unit suffers wounds equal to result, no armour or cover saves.
6. Warp Blast - 2 charges
Witchfire power, either burst or lance. This is the standard Zoanthrope Warp Blast.
1. What can take regeneration?
Hive Tyrant, Tervigon, Prime, Broodlord, Haruspex, Harpy, Crone, Carnifex, Trygon and Prime, Mawloc (earlier I made a mistake and said they couldn't), Exocrine, and Tyrannofex.
Regen is a 30 point biomorph. Now you roll a single D6, and regen 1 wound on a 4+. Not one dice per wound lost.
2. Does anything have an invulnerable save, and if yes, what (other than Zoanthropes)?
Not that I see.
3. This one is wishful thinking on my part, but I assume there is no Codex special rule which allows certain units to run and assault (some of the earlier debunked rumours were mentioning things like this, and if it were true, it would IMHO solve all the other problems with this codex)?
Not that I see.
4. Do the rumoured upgrades for the tervigon exist? I'm talking about the ones which allow unlimited spawns or 4D6 spawns.
Not that I see.
5. What can take flesh hooks or whatever they're called (the things that act like frag grenades)?
Warriors and Prime.
6. You said the Haruspex was useful against infantry and that was about it, and then said it had a S6 tongue attack, which i'm a little confused about. As far as you can see, can it still use smash (being a monstrous creature) to get 2 S10 AP2 attacks against vehicles (or anything else), or more attacks if it is wounded?
Haruspex (160 pts)
WS 3, BS 3, S 6, T 6, W 5, I 3, A 3, Ld 7, Sv 3+
Feeder Beast - If a Haruspex inflicts at least one unsaved one in the assault phase, it recovers a single wound at the end of that phase.
Rapacious Hunger - In the turn in which it charges, every unsaved wound it inflicts in close combat allows it to make an additional attack. These bonus attacks cannot generate further attacks. Wounds that inflict instant death generate only one bonus attack, and wounds caused by HW, acid blood, or tail do not benefit from this rule.
The Haruspex has a Grasping tongue - 12', S6, AP 2, Assault 1, Gulp!
Gulp! A to hit roll of a 6 is a precision shot.
7. Although scything talons now suck apparently, does the trygon still reroll all misses in CC via some new special rule or whatever, or does he just get an extra attack for two sets of scything talons, and attack at AP6 (useless)?
He gets an extra attack. He is monstrous though, so it's always at AP2 right? I dunno, because the entry for ST says Str (user) and AP 6
8. Other than the points decrease, is the Tyrannofex the same, as in, is the Rupture cannon still S10 AP4 two shots?
Same. The cannon is 30 points (dunno what it used to be)
What about biovores and spore mines?
Biovore (40 pts)
WS 3, BS 3, S 4, T 4, W 3, I 2, A 2, Ld 6, Sv 4+
Spore Mine Launcher 48', S 4, AP 4, Assault 1, Barrage, Last Blast, Spore Burst
Rules are a bit long winded, but seem about the same.
Pyrovore looks about the same as well. Template weapon, acid maw, explode when you kill them, etc.
Zoanthropes can take one other Psyker power as a brotherhood (they always have Warp Blast)
Is the Death Leaper an Independent Character or just a solo-deploying HQ Lictor?
Infantry (Character), HQ, 130 points, Mind Eater Warlord Trait (2 vp for killing characters in challenge)
WS 9, BS 3, S 6, T 4, W 3, I 7, A 4, Ld 10, Sv 5+
Rending claws, ST, flesh hooks
Chameleonic skin, Deep Strike, Fear, Fleet, Hit & Run, Infiltrate, Instinctive Behaviur (Lurk), Move Through Cover, Phermone Trail, Stealth
It's After Me! (Lower a character's Ld by D3)
Where is It (Enemy models can only fire snap shots when targeting Deathleaper)
Raveners (30 pts per model)
WS 5, BS 3, S 4, T 4, W 3, I 5, A 3, Ld 6, Sv 5+
Deep strike, Instinct (Feed), two pairs of ST. Any Ravener can exchange one pair of ST for Rending claws at 5 points per model.
Can take Spinefists (3 pts), Devourer (5 pts), Deathspitter (10 pts). One Ravener in the *army* may be upgraded to Red Terror for 85 points:
Red Terror
WS 6, BS 3, S 5, T 5, W 3, I 5, A 4, Ld 8, Sv 4+
Two pairs of ST, Prehensile Pincer (see that tail list I posted up there), Deep Strike, Swallow Whole (if it hits with 4 attacks, it auto kills a guy. The guys gets his invuln save and that's it)
Carnifex (120 points)
WS 3, BS 3, S 9, T 6, W 4, I 2, A 3, Ld 7, Sv 3+
Fearless, Instinct (Feed), Living Battering Ram (D3 Hammer of Wrath hits)
May replace ST with crushing claws (15 pts)
May take any bio-morph, spine banks (5 pts), or Bio Plasma (20 pts). May take Thresher scythe (10 pts) or Bone Mace (15 pts) tail morphs.
(As before, Fail Ld and be out of synapse for this to happen)
Instinct (Lurk)
1 - 3: Survive. The unit is treated as having failed a morale test and immediately falls back
4 - 5: Seek Cover. In the movement phase the unit is not slowed by difficult terrain, but still must take Dangerous Terrain Tests. In the shooting phase, the unit can run, but can only shoot if it is in a building or area terrain. The unit cannot charge in assault.
6: Stalk. As 4-5, but gains stealth.
Instinct (Hunt)
1 - 3: Burrow and Hide. The unit immediately goes to ground. If there is a fearless model, use results from 4-5 instead.
4- 5: Prowl. In the shooting phase, the unit cannot Run and must shoot at the closest enemy unit within range and line of sight. If there is no viable target, do nothing. Cannot charge in assault.
6: Destroy. As Prowl above. Also gains preferred enemy.
Instinct (Feed)
1-3: Cannibalistic Hunger. Unit suffers hits equal to number of models in the unit. Use majority strength, AP -. Wounds allocated by owning players. Armour saves okay, but no cover saves. Unit can do nothing. If it is a single model, use devour (as if rolled 4 - 5).
4-5: Devour. Cannot shoot or run. In Assault, must charge closest enemy or do nothing.
6: Kill. As above, but gains rage.
Revx, Hive Tyrant, Swarmlord entries both say they generate their powers from Powers of the Hivemind. Broodlord always only knows The Horror.
arnestig, Carnifex can buy their bio plasma and can buy bio cannons, sorry missed it out while typing. Carnifex can buy every damn thing from the looks of it
kertoan, venomthrope still 45 points.
WS 3, BS 3, S 4, T 4, W 2, I 3, A 2, Ld 6, Sv 5+.
Lash whips (+3 Init), confers shrouded on self and wihin 6'. Poisoned 2+, Instinct (Feed). Toxic Miasma: Usable once per game, in assault. During init step 1, all enemy units enaged in combat take hits = models in base to base. Hits are Str 3, Ap -. Poisoned and ignores cover.
Nameless, Brainleech Devourer is 18', S6, AP-, Assault 6.
Note that Hive guard Impaler cannon is unchanged (still Str 8, no need line of sight, etc.) Hive guard are 55 pts with same stats
Swarmlord (285 pts)
Ws 9, BS 4, S6, T 6, W 5, I 6, A 4, Ld 10, Sv 3+
MC, Character
Warlord Trait: Synaptic Lynchpin (18' synapse)
Psyker level 3, Shadow in the Warp, Synapse
Alien Cunning: Must add 1 to reserve rolls
Swarm Leader: At beginning of turn, choose either Swarmlord's Unit, r a friendly unit within 18'. Unit gains Furious Charge, Monster Hunter, or Preferred Enemy till end of turn.
Swarmlord generates powers from Pwers of the Hivemind.
TWO pairs of Bone Sabres: Str User, AP2, Blade Parry (4+ invuln against wounds caused by melee weapons), Instant Death
09.01.2014 via jackedup @tth
Hive Crone 155 Pts
WS 3, BS 3, S 5, T 5, W 5, I 5, A 3, Ld 10, Sv 4+
May take one of the following:
Stinger Salvo (10 pts)
Cluster Spines (15 pts)
May take items from Biomorphs List
Weapons and Biomorphs: Drool Cannon, Four Tentaclids, Scything Talons
Drool Cannon - (Template, S 6, AP 4, Assault 1)
Tentaclids - (36', S 5, AP 5, Assault 1, Haywire, Seeking, One Use Only)
Seeking - If a model makies a shooting attack with this weapon against either a zooming flyer or swooping FMC, it re-rolls failed to-hit rolls made with this weapon
Raking Strike - A hive crone's vector strike is resolved as S8
FMC, Fearless, Instinct (Feed), Raking Strike
Tervigon Spawn:
The spawned unit cannot move during the movement phase in which it is spawned, nor can it charge this turn, but it is free to shoot or run as normal.
HG Shock Cannon:
18', Str 5, AP 5, Blast, Haywire, Assault 1
Any HG can replace its Impaler cannon with a shock cannon for 5 pts
The first time the Mawloc doesn't clear the area, you resolve the s6 ap 2 hit again. Two hits is kind of a good thing right? No?
Okay this is the exact wording on the Mawloc page, just for clarity:
Burrow: An unengaged MAwloc can, at any point during its movement phases from the second game turn onwards, elect to burrow. If it does so, remove it from the table and place it into ongoing reserves. A mawloc cannot deep strike and burrow in the same turn.
Terror from the deep: When arriving from deep strike reserve, a mawloc can choose to deep strike onto a point occupied by another model (friend or foe) - roll for scatter as normal. If a Mawloc deep strikes onto a point occupied by another model, do not roll on the deep strike mishap tab;e. Instead, place the large blast marker directly over the spot the Mawloc is deep striking onto. All units except flyers and flying monstrous creatures beneath the blast marker suffer a number of Str 6, AP 2 hits with the Ignores Cover special rule equal to the number of models that unit has underneath the blast marker. If the blast marker is on a multi-level ruin, only models on the lowest level of the ruin count as being under the blast marker. For wound allocation purposes, assume the attack is coming from the centre of the blast marker. Hits against vehicles are resolved against their side armour.
If, after removing casualties, it is now possible to place the Mawloc on the table on the spot where the blast marker landed, then do so, even if this is within 1" of another model (but not if it would be in base contact with, or occupying the same space as, another model). If it is not possible to place the Mawloc, replace the large blast marker on the spot and resolve another round of damage as detailed above. If, after removing casualties for the second time, it is still not possible to place the Mawloc, roll on the deep strike mishap table.
Biovore (40 pts)
Instinct (Hunt)
Spore Mine Launcher - 48", Str 4, AP 4, Assault 1, Barrage, Large Blast, Spore Burst
I do not see anything else special about the Biovore in the book...
Trygon Tunnel Wording:
Subterranean assault - If, when a Trygon (or Trygon Prime) deploys via deep strike, it scatters on top of impassable terrain or another model (friend or foe), reduce the scatgter distance by the minimum required to avoid the obstacle.
After the Trygon (or Trygon Prime) has emerged, mark the position under the creature's base with a suitable marker - this represents the tunnel left by uts emergence. Any friendly Tyranid Infantry unit that arrives from reserve in subsequent turns may emerge from the Trygon's tunnel instead of arriving from reserve as normal. Only one unit may emerge from each tunnel marker each turn.
If any unit chooses to do so, place the entire unit so that all of its models are wholly within 6" of the centre of the marker and in unit coherency. These models cannot be placed within 1" of enemy models ir within impassable terrain; if any models cannot be placed, these excess models are removed as casualties. A unit may not move or charge on the same turn it arrives from a Trygon's tunnel, but may shoot or run.
Spore Mine:
Floating Death - Spore mines move 3" in the movement phase and, when they run or charge, move half the distance rolled. Spore mines are never slowed by difficult terrain, but must take dangerous terrain tests as normal.
Spore mines do not attack in close combat. Instead, at Initiative Step 10,. the entire clister detonates! To resolve this, centre the blast market over any one of the unit's spore mines. Eavery other unit (friend or foe) under the blast marker suffers a number ofhits equal to the number of models under the blast marker. The strength of these hits is equal to 4, but is increased by 1 for each additional spire mine in the detonating cluster (to a maximum of S10). These hits are resolved at AP 4 and ignore cover saves. Once all hits have been resolved, remove all models in the spore mine cluster from play as casualties.
via akaiyou @tth
Basic Biomorphs
may replace devourer with one of the following
Scything Talons - Free
Spinefists - Free
Deathspitter - 5 pts
Basic Biocannons
Barbed Strangler - 10 pts
Venom Cannon - 10 pts
Monstrous Biocannons
may replace any pair of scything talons with one of the following
Twin-linked Deathspitter - 5 pts
Stranglethorn Cannon - 15 pts (note 1)
Brainleech Devourers - 15 pts
Heavy Venom Cannon - 20 pts (note 1)
Combat Bioweapons
A model may replace any pair of scything talons with one of the following
Rending Claws - 5 pts
Bonesword - 15 pts
Bonesword & Lashwhip - 20 pts
Thorax Biomorphs
A model may take one of the following
Thorax Swarm (grubs) - 10 pts
Thorax Swarm (beetles) - 10 pts
Thorax Swarm (larvae) - 10 pts
Biomorphs
A model may take one of each of the following
Toxin Sacs - 10 pts
Adrenal Glands - 15 pts
Acid Blood - 15 pts (note 2)
Regeneration - 30 pts
Tyranid Bio-Artefacts
A model may replace any pair of scything talons for one of the following. Only 1 of each artefact per army
The Maw Claws of Thyrax - 10 pts
The Miasma Cannon - 25 pts
The Norm Crown - 40 pts (does not replace weapon)
The Ymgarl Factor - 40 pts (does not replace weapon)
The Reaper of Obliterax - 45 pts
Note - 1 per model. A model may not take a stranglethorn cannon and a heavy venom cannon
Note - 2 cannot be taken by Haruspex
Hive Tyrant - 165 pts
Notable Changes
+1 BS
Weapons & Biomorphs
Two pairs of Scything Talons
Special Rules
Synapse Creature
Psychic Mastery 2
Shadow in the Warp
Psychic
A Hive Tyrant generates his powers from the Powers of the Hive Mind discipline.
May Select from the following lists: Monstrous Biocannons, Combat Bioweapons, Thorax Biomorphs, Biomorphs and Tyranid Bio-Artefacts
May take any of the following
Indescribable Horror - 10 Pts
Old Adversary - 15 pts
Hive Commander - 20 pts
Prehensile Pincer (tail biomorph) - 10 pts
Wings - 35 pts
Tyrant Guard Brood - 50 pts
May include 1 unit of Tyrant Guard for each Hive Tyrant (Including Swarmlord) in your army. These do not count on the Force Org Chart
Notable Stat Changes
-1 A
Weapons & Biomorphs
Rending Claws
Scything Talons
Special Rules
IB (Feed)
Blind Rampage
Shield Wall
Very Bulky
May include up to 2 additional Tyrant Guard - 50 pts
Any model may replace its scything talons with
Crushing Claws - 20 pts
The unit may take any of the following
Toxin Sacs - 3 pts/model
Adrenal Glands - 5pts/model
Tervigon - 195 pts
+1 I
Weapons & Biomorphs
Scything Talons
Stinger Salvo
Special Rules
Synapse Creature
Psychic Mastery 1
Shadow in the Warp
Brood Progenitor
Spawn Termagants
Synaptic Backlash
Psychic
A Tervigon generates his powers from the Powers of the Hive Mind discipline.
May Select from the following lists: Thorax Biomorphs, Biomorphs and Tyranid Bio-Artefacts
May exchange his scything talons with crushing claws - 15 pts
May exchange his stinger salvo with cluster spines - 5 pts
Tyranid Prime - 125 pts
Weapons & Biomorphs
Scything Talons
Devourer
Special Rules
Synapse Creature
Shadow in the Warp
Alpha Warrior
Very Bulky
May Select from the following lists: Basic Bioweapons, Combat Bioweapons, Biomorphs and Tyranid Bio-Artefacts
May take flesh hooks - 5 pts
Ja, hatte ich gestern Abend schon gelesen. Würde mich freuen und vielleicht ist es nich RC, der mit SM viel zu beschäftigt war. Werden sehen.
Es klingt auf jeden Fall plausibel, da BTs jetzt ja als eigener Monat rausfallen UND schon seit Frühjahr immer wieder gesagt wurde Orks/Tyraniden seien austauschbar.
Wenn jetzt im November Tyras kommen, wäre das dann allerdings 4 40k Monate in Folge, da die Inquisitor-Box für Oktober ja auch relativ fix scheint.
Jedenfalls passt zum Tyra-Gerücht, dass es kein Orktober geben wird, weil diese auf das 2. Quartal 2014 verschoben wurden.
Ich freue mich auf einen Tyranivember.
@Makaku:
Deine Modellrechnung geht so nicht auf. Wir wissen doch schon seit einiger Zeit, dass jeder 6th Release von mindestems einem komplett neuem Release begleitet wird, oft auch ein großes Kit, bei den SM jetzt auch wieder. Dazu evtl. paar neue Plastikbausätze und vielleicht sogar neue unique units.
Könnte natürlich sein, dass das große Kit die Harpyie/Variante und Transportspore/Angriffsvariante sowie evtl. Biovore/überabeitete Pyrovore wird und es dann quasi nichts neues geben wird, was ich mir aber nicht vorstellen kann, da man ja grade bei den Tyraniden relativ einfach neue Einheiten erfinden kann und das a) bisher bei jedem Tyra-Codex der und b) auch bei allen anderen neuen Codizes der Fall war.
Puh, auch wenn es mich freuen würde, ich halte es für sehr unwahrscheinlich. Ich habe auch keine genaue Vorstellung was man bei den Tyras machen könnte. Die Spore hat ja jeder Tyra-Spieler sich schon irgendwie selbst gebastelt oder besorgt. Ausreichend viele Modelle gibt es auch, man hat sogar für jeden Bereich mehrere Spezialisten. Mit der Harpye kann man noch punkten, gibt wenig Spieler bis jetzt, die sich eine gebaut haben.
Sicherlich bedarf der Codex ein paar Änderungen, man merkt schon arg, dass er auf die letzte Edition ausgelegt war. Nun, ich habe hier jedenfalls das Gefühl, dass bei den Tyras eher der Wunsche der Vater des Gedanken ist. Außerdem gibt es weitaus ältere Codizes! Warten wir ab, ob sich die Gerüchte verdichten.
Jo, aber wie gesagt, vorhandene Modelle sind nicht entscheidend, in Zweifelsfall werden neue erfunden.
Siehe Centurions, Riptide, Wraith Knight, Helldrake und das andere ChaosDing, DA-Ritter(Bikes und Termis) sowie div. unnütze Aircraft-Varianten.
GW wird für eine brandneue super unit, die noch keiner haben kann, ohne Rücksicht auf Verluste einfach eine neue Einheit erfinden. Aber grade bei den Tyraniden wäre es mal ausnahmsweise vllt. sogar nicht völlig abwegig.
Also ich spiele Tyraniden seit 2006 und habe bisher keine Spore in meiner Armee... Der Tervigon kam doch auch erst letztes Jahr raus und die Eigenbauten sind zum Großteil aus den Armeen verschwunden. Sollte die Spore dazu noch richtig gut aussehen, wird GW schon einige davon absetzen können.
Persönlich hoffe ich, das die Pyrovore mit fetten Regeln ausgestattet wird. Dann weiß ich auch, warum ich 2010 gleich 3 Stk gekauft und bemalt hatte (damals zum Glück aus Metall).
Es gibt nur noch Orks und Soros (wobei die wohl ewig auf sich warten lassen) da Templar ja bei den SM unterkommen. Also soviel ist es nicht mehr.
Meine Herren Leute gehts eigentlich noch? Wir sind gerade auf der zweiten Seite und es gibt absolut nichts als VAGE Gerüchte und schon fängt das Gezeter. Warum betreibt ihr eigentlich das Hobby wenn GW in Euren Augen doch eh nur scheiße baut und Evil Company of the century ist?
deswegen Spiele ich ja kein 40k mehr...da darf ich meckern 😛
