40k GW Labyrinth of the Necrons Brettspiel 2018
Warmaster
12. Juni 2014
7.322
374
44.126
Update 2 - Von GW auf der Toy Fair vorgestellt
Update 1
Es wurden Fotos geleakt, die einige der Gerüchte bestätigen. Das Spiel heißt Labyrinth of the Necrons und scheint tatsächlich ein Warhammer/Hero/Star Quest zu werden
https://www.dakkadakka.com/dakkaforum/posts/list/751121.page#9840438
https://www.dakkadakka.com/dakkafor...e;jsessionid=6EE46B9A500B4E635B5ECD67BC68FCFC
Ursprünglicher Post
James Hewitt äußerte in einem Podcast im November dass er bei GW neben Adeptus Titanicus an einem weiteren noch unveröffentlichten Boxed Game gearbeitet hatte. Bisher war noch nichts weiter durchgesickert.
Heute gab es einen interessanten Post im DakkaDakka Forum
Cyphertheory - DakkaDakka
A boxed game I have heard of, which may link into a summer 40k event/campaign is a "warhammer quest" style/based 40k game based in a necron tomb (note this could be a tomb world, tomb ship or necron tech, it was not clear) and apparently leads to a race to reclaim a relic between abaddon and guilliman and is a progression of the narrative.
Details were light, but was said to have some great references to rogue trader and earlier days of 40k lore.
I would only say that the main narrative of 40k is imperium vs chaos so it's not straying from the core "plot" of the new dark imperium
It was inferred it was a narrative "race" as a backdrop, just for clarity
One other tidbit was "Genestealers, but not as we have seen them before" I have no idea what that was to be, when it was to be out etc, and I don't think it has a direct connection to the other stuff. I really don't stand behind it as something I am confidant is a solid rumour, just putting it out there. One to keep in the back of your mind I guess.
Sorry, I really wish I had a tiny bit more to flesh that out but I don't. I know nothing more that that post
https://www.dakkadakka.com/dakkaforum/posts/preList/748328/9780313.page#9780313
Die Quelle war bisher nicht schlecht (siehe Post History).
Dennoch ist das nur ein erster Hinweis. Dieses Spiel muss auch nicht zwangsläufig mit James Hewitts Arbeit zusammenhängen.
Sobald es Neues gibt, erfolgt ein Update.
Warhammer Quest (bitte ohne Gamemaster) im 40k Universum? Wäre sofort gekauft.
Ich denke, es sollten beide Möglichkeiten gegeben sein. Spiele ohne GM haben mittelfristig meist keinen großen Wiederspielwert.
Nach dem, was man so herausliest (wenn es denn stimmt) wäre der GM in dem Fall auch eher eine dritte Fraktion, was noch interessanter wäre.
Interessant, aber kommt das wirklich?
Natürlich. Imperiale Symbionten und Chaos-Genestealers, die sich einen Wettlauf liefern um den Necrons Artefakte abzuluchsen sind etwas, was sich die Spieler schon lange gewünscht haben.😎
Ich würde erstmal nichts drauf geben - kommt etwas, okay. Wenn nicht, dann nicht.
Ein WHQ-Spiel für 40k wäre an sich nachvollziehbar, wäre ja auch nichts neues. "Genestealers, but not as we have seen them before" kann alles mögliche bedeuten, von Xenos-Hybriden über Chaossymbionten (gab im Codex eine neuere Anspielung) bis hin zu etwas, was mit Symbionten nichts zu tun hat (irgendwer stiehlt halt Erbgut für irgendwelche sinistren Zwecke). Wer weiß.
Und ich lese da, dass Adeptus Titanicus sich eventuell noch weiter verzögert... 🙁
Nein, dies sind zwei unterschiedliche Spiele, Adeptus Titanicus ist bereits bekannt, James arbeitete nach eigener Aussage an einem weiteren, noch nicht angekündigten, unbekanntem Spiel
... das ist doch schon StarQuest oder nicht, bzw. wie groß ist der Unterschied zwischen HeroQuest und WarhammerQuest?
Der ist in etwa so groß wie zwischen heroquest und warhammer (ohne quest). Oder Betrayal of calth verglichen mit 40K. Ausserdem ist Starquest nun auch schon etwas über 20 Jahre out of print, da schadet ein neues Spiel nicht.
Also ein gewisser Unterschied besteht schon. Zum einen im organisatorischen wenn man so will, denn bei Warhammer Quest sollten die Modelle zunächst zusammengebaut werden, HeroQuest kommt mit bereits montierten und eigentlich auch unterschiedlich gefärbten Figuren, in Ausnahmen müssen vielleicht einzelne große Modelle zusammengefügt werden, aber der Gros ist bereits fertig montiert und direkt spielbar.
Vom Spielprinzip sind sich beide Systeme wieder sehr ähnlich, was auch auf die ähnlich klingenden Namen zurückgeführt werden kann, denn bei beiden Quests geht es darum, einen vorher gewählten Helden, der gewisse Eigenschaften hat, durch ein Labyrinth oder Dungeon zu führen und den Dungeon Lord und seine Schergen zu besiegen. Bei den Helden und Schurken unterscheiden sich beide Systeme natürlich. Allerdings bieten auch beide Systeme gewisse Erweiterungsmöglichkeiten, wodurch das Spielprinzip interessanter werden könnte.....
Meines Erachtens liegt ein beträchtlicher Unterschied bei den Modellen, die bei WarhammerQuest zwar zusammengebaut werden sollten, dafür aber umso detaillierter sind. Die Heldenauswahl ist bei Warhammer Quest auch größer, allerdings müssten die dann dazu gekauft werden.
Ach ja und Hero Quest und Warhammer Quest spielen natürlich annährend im gleichen Zeitalter.
@Lomax:
Sorry aber das ist nicht richtig. Das Spielprinzip von WH Quest ist komplett was anderes als Heroquest. Allein der Anspruch von Heroquest ist schon sehr niedrig, auf Kinder ausgelegt. Wenn man das heute als Erwachsener in der Urfassung spielt wird man sich sehr schnell langweilen. Die Monster sind schwach, es gibt keine Einschränkungen beim Schätze oder Fallen suchen, die Charaktere sind sich sehr ähnlich usw.
WH Quest wird im Silvertower mittels KI gespielt, zufällige Karten lassen den Silvertower bei jeder Queste neu entstehen.
Hammerhal hat zwar vorgeschriebene Dungeons aber selbst die sind meilenweit von einem Heroquest entfernt, weil hier unterschiedliche Räume auch unterschiedliche Mechaniken auslösen können.
Also zu sagen dass sich die Spiele lediglich in den Miniaturen unterscheiden ist absolut nicht richtig.
@Lomax:
Ich hatte auch geschrieben, das ein "beträchtlicher Unterschied" bei den Miniaturen liegt, dass das nicht der einzige Unterschied ist hatte ich auch geschrieben:
"Bei den Helden und Schurken unterscheiden sich beide Systeme natürlich," auch. Dass die Monster bei Heroquest schwach wären, kann man so auch nicht sagen, tatsächlich wurde ja bei WarhammerQuest Silvertower oft bemängelt, dass die Helden oder einige Helden so schnell durchkommen bei den Gegnern und die Spielweise so kurz wäre . Bei Heroquest gibt es durchaus auch anspruchsvollere Monster als bei Silvertower, z.B. Orks, Gargoyles, SKelette, etc.
WarhammerQuest Silvertower ist natürlich im Warhammer Universum angesiedelt und dementsprechend kommen dort auch Gegner vor, die es bei Heroquest z.B. gar nicht gibt, wie die Tzaangors bzw. die Einheiten von Tzeentch.
Ich habe das ganz alte Heroquest aus den 90er Jahren gespielt, wo es als Spielfläche noch eine einzelne Spielplatte gab. Bei WarhammerQuest kann man das Spielbrett modular aufbauen durch einzelne kleinere Spielplatten, dadurch wird das Spiel natürlich individueller.
Meiner Meinung nach ist WarhammerQuest Silvertower als ein verbessertes HeroQUest anzusehen, zum einen wegen den Miniaturen selbst, aber auch wegen der großen Auswahl an Helden, und wegen dem Warhammer Universum insgesamt, denn das Warhammer Universum bietet story mäßig viel.
Wenn man schon Vergleiche anstellt sollte man das alte Heroquest eher mit dem neuen Warhammer Quest Shadow over Hammerhal vergleichen, da beide Spiele mit einem Spielleiter gespielt werden. Dadurch werden sie sich schnell sehr viel ähnlicher. Silver Tower kann man eher mit der spielleiterlosen Version vom alten Warhammer Quest (95) vergleichen was obige Punkte der Spielmechanik betrifft.
Nebenbei bemerkt ist Heroquest ebenfalls in der (alten) Warhammerwelt angesiedelt und es gibt durchaus ein paar Bezüge auf Heroquest in den Chaosarmeebüchern versteckt.
