Ich finde wir sollten das hier nochmal ins Auge fassen, da die neuen FAQ's doch wie befürchtet sehr löchrig sind. Die Liste von Changer hab ich mal kopiert und ein wenig angepasst (in den FAQ's geklärte Sachen weggeworfen, paar Sachen ergänzt (kursiv geschrieben, einige sprachliche Schnitzer ausgebügelt).
Bitte fügt noch zu klärende Dinge bald (jetzt 😉) hinzu. Was mir noch eingefallen ist steht ganz am Ende dieses Posts. Und wer suspekte Englischkenntnisse findet darf sie natürlich gerne korrigieren ^^).
General questions
-Should all entries in all Books named in the same way use the same rules (e.g.
bionics, Land Raider, Assault Cannon etc)? If yes, please state the correct versions
-Are IC with Retinue still ICs? (especially for close combat purposes)
-May Units with Fleet of Foot/Claw/etc use this rule in a turn they entered the table via deep strike or disembarked from a closed-top vehicle?
-What happens to units that Deep Strike into friendly units?
- Is it possible for a model to strike with more than 10 attacks? As the RB states, a characteristics value cannot exceed 10. But some of us think that the effective number of attacks is not limited in this way because you take the profile value (which is limited to 10 attacks) and add a number of modifiers (2 cc weapons, Mark of Khorne, ...) which could result in a value larger than 10.
- A similar question: Is the *effective* Initiative value limited to 10? Could an upgraded Hive Tyrant (I6) with Bioplasma attack with I12?
- close combat and cover: Do we have to assume that the Initiative *characteristics* is being set to 10 so that any modifiers to Initiative are being applied *afterwards*? For example, if a unit of Slaanesh Chaos Space Marines with Warp Scream and Frag Grenades assaults a unit in cover, do their enemies strike at initiative 9 (ini set to then, then lowered by 1) or at initiative 10 (= do whatever you want with ini, simply rise it to 10 afterwards)?
-Does an upgrade character in a unit confer its Leadership value on its unit?
Codex Space Marines
-May the Techmarine be equipped with Servo-harness and Bike/jumppack?
-May the Techmarine use Servo-Arm with Bike/Jumppack?
-Does the plasma pistol of the Servoharness count as additional close combat
Weapon? The FAQ simply says it provides an extra attack
-Does the familiar of a libarian slow him down if he uses a bike/jumppack?
-Does "Be swift as the wind" include Scout Bikes and Attack Bikes?
-How many "slots" does an modell with terminator armour occupy when transported in a vehicle?
-Which chapters may use Drop Pods?
-Please state that Terminators do wear Terminator Armour.
Codex Chaos Space Marines
-Do the limitations concerning rules that have been converted to Universal Special Rules still apply? I.e.: May a Daemon Prince with Stature, a model/unit with the Mark of Khorne, with Terminator Armour or with bikes infiltrate now? There is great rumour about this as some rules in the RB, and especially the Infiltrate rule, do not state any limitations, but is supposed to replace the rules in the codices.
-Is the Slaanesh power "Siren" meant to work both in the Shooting and the Assault
phase, making the model virtually invulnerable? To us this would seem to be a great imbalance.
- How does the Lash of Torment work in 4th edition if given to an Independent character? As the model counts as a separate unit in close combat it seems to be useless: At least one model of the own unit must be in base to base contact in order to get the attacks, so the character - fighting on his own - does not count as being in CC if not in base contact and may therefore not strike.
-Do IC with a mark of chaos receive a free chaos icon?
-Can you use “feel no pain” to ignore wounds caused by the psychic ability “mind war”,dangerous terrain or perils of the warp?
-What is meant with “area of effect” in the description of the rule “collar of Khorne”? Is this supposed to be the area, where the psychic ability CAN affect, or is this the area, where it actually affects? Can i.e. a psychic ability be blocked, which is not targeted at the bearer? Can the ability of a tyranid Synapse Creature be blocked, if the bearer is within 12” around it?
-Can a model with a berserker glaive be equipped with daemonic speed or daemonic flight? In the 3rd reprint of the English codex this was negated, but please include it in the FAQ so that every player can verify it.
-If the aspiring champion of a Khorne berzerker unit gets daemonic speed or daemonic flight, does the whole unit cease to check for Blood Frenzy?
-Are independent Charachters with the Mark of Tzeentch allowed to take Veteran Skills?
-Are Screamers of Tzeentch and Raptors allowed to use their fall back rule in the following situations?
a) they fight against a unit and wipe out all their members
b) they fight against a Vehicle without a WS (i.e a Leman Russ) and don't destroy it
c) they fight against a Vehicle without a WS and destroy it
-Do you re-roll already rerolled throws for determining minor psychic powers? E.g., if you throw 3 dice and roll a 'one' and 2 'threes'. You reroll the 'three' and get another 'three'. Can you reroll this throw again?
-May Daemons appear at Icons that belong to pinned units?
-Do attacks from Nurgling Infestation count as attacks from a Monstrous Creature if a Daemon Prince with Daemonic Stature has them?
-Are Iron Warriors supposed to be able to field vehicles that are aligned to a Chaos God?
-May a Defiler be given the Destroyer upgrade? While the first printing of the Codex does not forbid it the second printing clearly does! However, the FAQ describes how to use Destroyer on Defilers ...
-May Daemons bound to a Daemon Icon arrive in turn 1?
Codex Tyranids
-Do multiple Lash Whips equipped on one creature stack?
-Can broods without the line "must be equipped identically"(such as Warriors and
Genestealers) be fitted with different biomorphs through out the brood? (ex: only
buy 1 feeder tendril, since the benefits aren't limited to just the 'stealer with them)
-Are the Adrenal Glands for WS and I considered to be separate biomorphs for the
purposes of "same biomorph cannot be taken more than once per model"?
-The Shadow in the Warp power says "any Perils of the Warp results are nullified." Is
this just for your enemy or does it affect your army too?
-How does The Shadow in The Warp interact with the Eldar Runes of Witnessing?
-May deep-striking units choose to lurk on the turn they arrive?
-Can a single warrior in a Warrior brood be given multiples of the heavy weapons? (i.e. 2 Barbed Stranglers in order to have them twin-linked).
-Can a Lictor hit and run after attacking a vehicle? (generally speaking: Does a close combat against a vehicle without WS count as "being involved in cc"?)
-Does a Lictor that deep strikes on top of another (friendly) Lictor get removed as a casualty?
-Suppose an enemy model deepstrikes withen 1" or onto a spore mine or mine cluster. which is destroyed, the mines, the enemy, or both?
-Are mace/scythe tail biomorphs subject to the benefits of rending?
-Was the split price for Barbed Stranglers on a Carnifex intended to be as such?
-Do lash whips affect friendly models that are in base contact?
-Is an attack using the Bio-Plasma biomorph subject to the benefits of rending?
-Do Bio Acid Spore Mines roll 2D6+3 against a Monolith?
-Do Biovore broods pay for their type of mines a) once per model, or b) once per unit? (e.g. does a unit of three Biovores have to pay 15 or 45 points for Bio Acid mines?)
Do a Hive Tyrant and his retinue of Tyrant Guards count as a single unit for victory point purposes or are they treated separately?
Codex Necrons
-How does the Deceiver's "Deceive" ability work when used against Fearless units? Do they have to flee in subsequent turns if the conditions for regouping aren't met or will they regroup automatically? The first case would lead to strange problems where Khorne Berserkers could be "escorted" to the table edge by some cheap Scarabs.
Codex Demonhunters
-Who is the target of the mystic special ability?The Drop Pod or the Squad/Dreadnought?
Codex Space Wolves
-May Space Wolves field two venerable Dreadnoughts?The one from the Codex and a normal one with the "venerable" upgrade?
Codex Dark Angels
-Does "Stubborn" count against the limit of wargear a model may have?
-Does the Chaplain in a Deathwing Army have to buy "Stubborn"?
-If so,does ist override "Fearless"?
-May both versions of chaplains use the Blades of Reason?
-Do special characters gain all new benefits according to their rank?(e.g. rites of
battle?)
-Do the special standarts override the sacred standart in codex:sm?
-May Ravenwing Landspeeder Deep strike?
-May the ravenwing field a Techmarine if he has a bike?
Codex Dark Eldar
-May models with a Hellion Skyboard fleet?
NICHT AUFGENOMMEN (von Changer während der Fragensammlung)
Allgemein:
-Darf ich Verluste durch die große Schablone auch frei wählen(wie bei der kleinen)?
-Wenn ich Waffen schnellfeuere, gilt dann der Radius in dem Verluste verursacht werden können,als 12"?
-Könne Psioniker nur eine Psikraft pro Zug verwenden?
-Sind die Hexenjäger/Dämonenjäger eine imperiale Armee?
Space Marines:
-Gilt Veil of Time für alle genannten Würfe?
-Darf der Techmarine ein Rhino/Razorback erhalten ohne Servitoren zu wählen?
-Darf ein Techmarine einen Servoharnisch und eine Terminatorrüstung erhalten?
-Sind Familiars Einzelmodelle?
Gelten die alten oder die neuen Regeln für Drop Pods,wenn ein Dreadnought sie verwenden will?
-Haben Scouts die Scout Sonderregel?
-Haben Scout Bikes die durch Gelände bewegen Sonderregel?
DARK ANGELS:
-Sind die Einträge aus dem CODEX SM so zu verstehen:
Großmeister=Meister,Meister=Captain,Held fällt weg?
-Sind die Gegenstände für Großmeister nun nur für Meister erhältlich?
-Dürfen Chars in Terminatorkommadotrupps immer schocken?
-Muss ich in einer Deathwing Armee nur noch Stubborn kaufen,wenn ich eine
Terminatorrüstung kaufe?
-Kann ich die Geheimnisklinge und ein Relikt kaufen?
-Sind die Blades of Reason ein Relikt?
-Darf der Deathwing einen Techmarine haben?
-Darf ein Ordenspriester in Terminatorrüstung die Blades of Reason verwenden?
-Darf eine Deathwing Armee Drop Pods verwenden?
-Verwenden Ravenwing Bikes,Attack Bikes,Landspeeder weiterhin alle Merkmale des
Codex😀A?
Blood Angels:
-Dürfen Blood Angels Chapter Traits oder besondere Fähigkeiten haben?
-Bekommen auch Servitoren den rasenden Angriff?
Space Wolves:
...das meiste was Mauga da aus dem Dev-Forum gefischt hat ^^°
Blood Angels:
ALLES was im Dev-Forum steht!
Tyraniden:
-Are IB tests meant to be LD based or Morale based?
-Would the benefit from the Symbiote Rippers biomorph take place before or after
the effects of the Thornback biomorph?
-If a Tyrant or Zoanthrope fail a Ld test in attempt to shoot the powered up version
of Warp Blast, can they still opt to use the low power version instead?
-Are SoB 'shield of faith', etc. considered to be wargear or an ability?
If an ability, are SoB with these abilities considered to be psykers? (for purposes of
hivemind power cancelling)
-Does bio-plasma still hit a skimmer or fast-moving vehicle on a roll of 4+?
-Do Rending Claws and MC's natural 2D6 stack?
Chaos:
-Do Chaos Space Marines with the “Rubric Sign” (p. 59) fight with Ini 4 in close combat and are allowed to make sweeping advances?
von mir wieder rausgeworfen (bitte nochmal prüfen ob ich auch nicht zuviel weggeworfen hab):
SM:
-May the ability "rites of battle" be used if the commander is not on the table (deep
striking or in a vehicle?)
Nein, jedenfalls mit Sicherheit nicht wenn der Commander in Reserve hockt. Der englische Codex sagt, dass er sich auf der Platte befinden muss (wie ist das im deutschen? Übersetzungsfehler?). Wie es ist wenn der Chef im Transporter sitzt weiß ich nicht. Zählen Modelle im Transporter in der 4th als "auf der Platte"? Bitte um Meinungen.
-Does the Psychic Power "Fury of the Ancients" require line of sight?
Im FAQ geklärt.
Tyra:
-Do Lash Whips effects stack from multiple models equipped with them?
-Does two twin-linked weapons mean it's double twin-linked or two separate
twin-linked weapons?
-Does being Fearless make Lictors and Carnifexes immune to the effects of failing an
IB test (falling back)?
-Does synapse make a tyranid immune to instant death by weapons that have a
strength over double the toughness value of the creature in synapse range?
Die Fragen bis hier sind mit dem FAQ geklärt (wenn auch in Sachen Liktor alles andere als befriedigend).
-If a Hive Tyrant or Carnifex (MC's that can shoot more than 1 weapon a turn) take 2
of the same weapon (making them twin-linked), can they then fire both as separate
TL weapons?
Diese Frage ist Blödsinn .. da hat jemand nicht verstanden was "synchronisiert" bedeutet.
-Can winged warriors be taken as an HQ choice?
Ebenfalls nicht sinnvoll, da der Codex sehr eindeutig ist --> nein, geht nicht.
-Does the addition of Crushing Claws to a Carnifex count against MC's ability to roll 2D6 for AP?
Erscheint mir sehr unsinnig. Die Klauen geben ja keinen Stärkebonus und haben auch keine seltsamen Sonderregeln, sondern verleihen nur eine variable Attackenzahl.
Bei den folgenden Fragen kenn ich mich nicht gut genug aus um beurteilen zu können ob es bereits eine Lösung gibt:
- die Frage nach dem Anführer einer DE Armee
- zählt ein CdI als reguläres HQ einer BT-Armee oder braucht man noch eine weitere HQ-Auswahl für Standardmissionen?
