10. Edition Winged Tyranid Prime verleiht Flüüüüüüüügel ?
Dachfenster
Regelkenner
30. September 2022
2.156
11
1.222
44.596
Eine attached Unit wird als eine Einheit behandelt. Wenn der WTP einem Trupp Warriors angeschlossen ist hat die Einheit alle Keywords von allen Modellen. Und Fly sagt das die ganze Einheit fliegen kann, korrekt ?
Core Rules :
LEADER
While a Bodyguard unit contains a Leader, it is
known as an Attached unit and, with t he exception
of rules that are triggered when units are destroyed
(pg 12), it is treated as a single unit for all rules
purposes .
Rules Commentary :
KEYWORDS
Some units can contain models that have different keywords. While
this is the case, such a unit is considered to have all of the keywords
of all of its models, and so is affected by any rule that applies to
units with any of those keywords. Remember that attacks are made
against units, not models.
FLY
If a unit’s datasheet has the Fly keyword, that unit is said to be
able to Fly.
  • Wow
Reaktionen: Naysmith
Fly:
FLYING
If a model can Fly, then when it makes...
und Commentary:
KEYWORDS
■ If a rule specifies that it applies to a model/unit with a Keyword, it
only applies to a model/unit with that keyword on its datasheet.
■ If a rule specifies that it applies to ‘non-Keyword’ models/units,
it only applies to models/units that do not have that keyword. For
example, if a rule applies to non-Vehicle units, it only applies to
units that do not have the Vehicle keyword.
■ Some units can contain models that have different keywords. While
Example: An Attached unit contains a Leader model with the Psyker
keyword. While that Leader is part of that unit, the entire unit is
considered to have the Psyker keyword. If that unit is attacked by
a weapon with the [ANTI-PSYKER 4+] ability, any unmodified Wound
roll of 4+ made against that unit scores a Critical Wound, even if the
attack itself is not allocated to that Leader model.
■ If a rule only applies to models with a specific keyword, then
it instead only applies to models in such a unit that have the
correct keyword
Reaktionen: necrow und M1K3
Rules Commentary überstimmt die Core Rules. Nach den Core Rules kann sich ein fliegendes Modell nur durch die Luft bewegen wenn es seine Bewegung auf Gelände beendet, oder drauf startet, S. 15. Im Rules Commentary Abbildung 4, S. 8, moving over Terrain, wird dem direkt widersprochen, da kann ein fliegendes Modell sich über Gelände durch die Luft bewegen.
Das stimmt tatsächlich. Der Wortlaut des Regelbuchs hat es auf das Model eingegrenzt. Der Rules Commentary sagt aber das es es für die Einheit gilt wenn das Keyword in der Einheit vorhanden ist.
Also doch (ein kleiner) nutzen für Flugscheiben.
Die Core Rules sagen Modell. Die Clarifications sagen auf s. 6 Unit. Und auf s.8 sagen sie wieder Modelle.
Modelle oder Unit?
Für mich sieht das nach einen typischen Fail aus. Vom Sinn her würde ich auf Modelle tippen.
Das widerspricht sich nicht. Seite 6 stellt klar alle Modelle gelten als hätten sie selber FLY. Seite 8 beschreibt ja nur nochmal wie das gehandhabt wird (falls ich was übersehen hab, bitte aufzeigen).
Erst einmal total intuitiv! Deswegen m.M.n. schlechtes Design. Beim zweiten hinsehen, aber eigentlich nur ein kleiner Buff, da M der Modelle die FLY bekommen ja gleich bleibt. Ein Boost den ich aus der Ferne nicht sooo riesig finde.
Bei Advance und Charge können die Warrior feindliche Modelle überspringen, bis zu 12". Beim Fallback müssen sie kein Desperate Escape Test machen wenn sie sich durch feindliche Modelle durchbewegen. Über Ruinen müssen sie sich nicht durch die Luft bewegen weil sie Infantrie sind, gehen einfach durch. Sie können Aircraft chargen. Ein Boost der nicht sooo riesig ist, aber auch nicht sooo klein.
woher kommt jetzt der Schluss, dass die Core Rules ausgehebelt werden? Eure zitierte Seite 6, sagt ja, dass nur Einheiten die Fly auf dem Datasheet haben, auch wirklich fliegen können. Hat die attached unit ein Datasheet? Nein. Hat der Prime eins mit Fly? Ja. Haben die Krieger eins mit Fly? Nein.
Völlig irre, ich hab das jetzt nochmal (drittes mal) gelesen (Seite 6) und zum ersten mal das datasheet nach unit's gelesen. @RareSide hat natürlich vollkommen recht. Es wird doch so gehandhabt, wie es sich schon intuitiv aufdrängt .
Gelernt: Langsamer GW Regeln lesen hilft ?.
@Dachfenster das ändert ja nix daran das beim Move Fly Modelweise und nicht Unitweise abgeprüft wird. Die Unit (aus Kriegern und Prime) mag zwar Fly haben, das datasheet der Krieger hat es aber nicht.
Es ist zwar eine Einheit aber die besteht aus zwei Datasheets und für die Bewegung der Modell werden die Datasheets betrachtet.
