FAQ
Q: Do Serpents taken as Dedicated Transport get +1 Ballistic Skill for being a part oft he Aspect Host or Dire Avenger Shrine Formation?
A: Yes.
Q: Can Eldar Jetbikes assault after they done a 2D6” move in the Assault phase?
A: No. They can either move 2D6” or declare a charge.
Q: Does the Runes of Fate special rule allow Deny the Witch even when the Farseer is not directly targeted or in Range?
A: No.
Q: Can the Iyanden Supplement still be used with the new Codex: Craftworlds?
A: Yes.
Q: Can a unit of Aspect Warriors with Exarch be joined by an Independent Character?
A: Yes.
Q: Does a unit of Striking Scorpions that Outflank vie their Infiltrate ability gain the benefits of Shadowstrike?
A: No.
Q: Can Eldar Warp Spiders still move as Jet Pack Infantry in the Assault phase if they have Warp jumped in the Movement phase?
A: Yes.
Q: Is it intentional that an Eldar Autarch with a Warp jump generator does not receive the ability to Flickerjump with a unit of Warp Spiders?
A: Yes.
Q: Do Swooping Hawks that start the game on the table and Skyleap on the first/subsequent turns re-enter the game via Deep Strike?
A: Yes – they are placed into Ongoing Reserve and will arraive by Deep Strike in the following turn.
Q: When used as a weapon, in what direction does the serpent shield fire?
A: As described in the serpent shield entry in the Appendix, it is treated as a hull-mounted weapon pointing forward.
Q: Does a Striking Scorpion Exarch armed with a scorpion’s claw and a scorpion chainsword get to add +1 to their Strength from the chainsword after applying the x2 to their Strength from the scorpion’s claw in addition to gaining +1 attack for having two close combat weapons?
A: No. A Striking Scorpion Exarch with a scorpion chainsword and a scorpion’s claw must choose which weapon they want to use in the Fight sub-phase. The other weapon grants them +1 Attack for having two close combat weapons, but no strength bonus. If the Exarch choose to attack with the scorpion chainsword they will have +1 Attack and strike at Strength 4 and AP6. If they choose to attack with the scorpion’s claw they have +1 Attack and strike at Strength 6 and AP2.
Q: If Jain Zar uses Disarming Strike on a Khorn Deamonkin character with Kor’lath, the Axe of Ruin, and chooses the axe as weapon they lose, does that prevent them from summoning a Bloodthirster of Unfettered Fury via the axe’s Caged Fury special rule if killed while disarmed?
A: Yes.
Q: Is Jain Zar’s Silent Death meant to have the Melee type?
A: Yes.
Q: Should Krandras have the Stalker special rule?
A: No.
Q: Is the Seer Council listed in the Craftworld Warhost the same as the Seer Council Formation?
A: Yes, the Seer Council listed in the Craftworld Warhost the a Seer Council Formation as presented in the codex.
Q: Can the Autarch’s The Path of Command special rule be used if the Autarch is in Reserve?
A: Yes.
Q: If a Warlock successfully manifests the Runes of Battle power Protect, is it only the Warlock who receives a 6+ save?
A: No. ‘Protect is a blessing that targets the Psyker. Whilst the power is in effect, the Psyker and his unit receive a +1 bonus to their Armor Save (to a maximum of 2+).’ The Warlock receives a 6+ Armor Save, and the unit they are joined to receive +1 to their Armor Save as well.
Q: Can you assault after using Battle Focus?
A: No. A unit that Ran in the Shooting phase cannot charge in the Assault phase.
Q: Am I right in thinking that two Farseers joined to the Warlock Conclave in the Seer Council cannot manifest the same power in the same Psychic phase?
A: Yes, you are correct. They and the Worlocks are a single unit, and a unit cannot attamp to manifest the same power twice in the same Psychic phase.
Errata
Page 124 – Warp Spiders, Special Rules, Flickerjump
Change the first sentence to read:
‘One per turn, when a unit with this special rule is chosen as the target of a shooting attack, it can immediately make a Warp Jump (pg 154), moving 2D6” instead of 6+2D6”, so long as it is not Falling Back or charging.’
Page 149 – Forge of Vaul, Ranged Weapons, Distortion Weapons, Distort Scythe
Change the last sentence of this rule to read:
‘Furthermore, a weapon with this special rule is assumed to have a Strength of 4 for the purposes of the No Escape rule and of determining if a hit has the Instant Death special rule.’
