da gebe ich dir recht *thumbs up* 🙂
- RELEASE DATE: "Late third quarter."
- RELEASE INFO: There will not be a Heavy unit for each faction released within the same window of time as we got the AT-ST and T-47, but they said heavies for each faction will be on the way.
- Surge tokens are not actions. They are only given out by other abilities (command cards, upgrades, etc.). You may use Surge tokens on attack, defense, and while using Guardian.
- Scale is not an action. Alex said it is always on, and thus applies whenever Grievous moves.
- Grievous's pistol armament: Melee - Range 2: 2 Black 2 White. Critical 1, Pierce 1, Versatile. (12 points).
- Versatile means the weapon can be added to a melee dice pool, or can be used to shoot at a target at range, while you are engaged with another unit in melee. (Arsenal 2, Greivous could melee 1 unit and shoot at another with the pistol; or add the pistol to his melee dice pool)
- Ion affects droids. They will lose 1 action per Ion token.
- Suppression does not affect droids same as it does non-droid units. They will not lose actions and do not gain cover. Droids can become panicked due to Suppression tokens, however.
- Aggressive Tactics gives out Surge tokens when a unit is issued an order. 10 points/maximum of 4 surges given out.
- Hope (Force; Light Side Only) (3 points) You gain Inspire 1.
- Disengage means you may exit a melee/engagement with only a normal move (standard move, any move, was unclear, but I think it just means you can freely move out as if the opposing unit was not there).
- Fire Support can be used even if a unit would panic during its activation. A sneaky way to get around panicking. When using fire support, everything (cover, LOS to minis, surge) is determined by the parent unit, the one performing the actual attack. If the parent unit has surge to hit/crit, then the entire pool has surge to hit/crit.
- Wheeled is a free action at the start of activation only.
- Phase I Clone Trooper Heavy Upgrade, DC-15: Range 1-4. 2 Red, Critical 1. (30 points).
- Phase I Clone Trooper Heavy Upgrade, Z-6: Range 1-3. 6 White. (25 points).
- B-1 Battle Droids Heavy Upgrade, E-SC: Range 1-3. 3 Black. (18 points).
- B-1 Battle Droids Heavy Upgrade, E60-R (Rocket Launcher): Range 2-4: 1 Red, 2 Black, Impact 2. (Exhausts; 20 points).
Ich werde im ersten Zug auf jeden Fall Republik starten. Ich will JEDIIIIIIIs!
Das sind aber nicht die gleichen modelle wie aus dem grundspiel oder? gleiche modelle mit gleichen posen ? - nein sind sie nicht, wie ich selbst festgestellt habe über folgenden link
https://www.fantasyflightgames.com/en/news/2019/7/19/the-last-of-the-jedi/
vader kanns nicht oft genug geben..... =) am besten gefällt mir noch das sondermodell von der convention, dass allerdings nicht auf dem freien markt verfügbar ist.
Stimmt, andere Figur und andere Daten auf den Karten.
Wenn du mal ganz andere Figuren haben willst, es gibt auf Facebook einen Russen der wirklich hübsche Figuren selber Knetet 🙂
Da gibt es auch Count Dooku oder Darth Maul.
