10. Edition Delayed Mutations
Dachfenster
Regelkenner
30. September 2022
2.195
11
1.236
44.596
Creations of Bile Infantry Modells bekommen Augmentations zu Beginn der Schlacht. Duplicate Augmentations haben keinen zusätzlichen Effekt, würfle ich zweimal das gleiche, bekomme ich die Augmentation nur einmal. Gilt das auch für das Stratagem ? Darf ich mit Delayed Mutations eine Augmentation wählen die ich bereits am Anfang der Schlacht gewürfelt/gewählt habe, und bekomme die Augmentation nochmal ? Also zB Toughness +2 ?
EXPERIMENTAL AUGMENTATIONS
At the start of the battle, select which
augmentations are active for Heretic
Astartes Infantry models (excluding
Damned models) from your army
until the end of the battle. To do so,
either select one from the list below,
or randomly determine two by
rolling two D6. If Fabius Bile is your
Warlord, when randomly determining
your augmentations, you can re‑roll
one or both of the dice. Duplicated
augmentations have no additional effect.
1 Cholinergic Accelerants: Add 1 to
the Attacks characteristic of melee
weapons equipped by this model.
2 Hyperadrenal Infusion: Add 2"
to the Move characteristic of
this model.
3 Paraneural Reactions: Improve
the Weapon Skill characteristic of
melee weapons equipped by this
model by 1.
4 Supracutaneous Chitination:
Improve the Toughness
characteristic of this model by 1.
5 Macrotensile Sinews: Add 1 to the
Strength characteristic of melee
6 Ophthalmic Enhancement:
Improve the Ballistic Skill
characteristic of ranged weapons
equipped by this model by 1.
DELAYED MUTATIONS
WHEN: Your Command phase.
TARGET: One Heretic Astartes Infantry unit
(excluding Damned units) from your army.
EFFECT: Your unit suffers D3 mortal wounds.
Then select one augmentation (see Experimental
Augmentations). Until the start of your next
Command phase, models in your unit have the
selected augmentation in addition to any other
augmentations they have.
Ich denke doppelt wählen geht auch mit dem Stratagem nicht. Das würde ich mit 2 Argumenten begründen:
1. Auch wenn man über das Stratagem eine weitere Augmention wählen kann, unterliegt diese Augmention den Regeln der Detachment Rule. Und diese erlaubt explizit nur 1 Augmention jeder Art.
2. Diese Passage des Stratagems ...
"Until the start of your next Command phase, models in your unit have the selected augmentation in addition to any other
augmentations they have."
... bezieht sich explizit auf "andere" Augmentions. Nicht auf dieselbe.
Reaktionen: Naysmith
See Experimental Augmentation ist ein ziemlich deutlicher Hinweis, das die dort gültigen Begrenzungen auch hier beim Strat Anwendung finden. Doppel haben keinen zusätzlichen Effekt.
Fragen in Reihenfolge beantwortet:
Ja.
Darfst Du, bringt aber keinen zusätzlichen Bonus!
Nein, s.o. .
Reaktionen: Imu-Sesh
Wenn ich dieser Argumentation folge, hätte kein Teil der Detachment Rule außerhalb "At the start ..." Gültigkeit. Inklusive der Erklärung der einzelnen Augmentions, die nur in der Detachment Rule stehen.
Das ist natürlich Quatsch. Deshalb übernehme ich für das Stratagem die Punkte, die nicht ausschließlich "At the start of the battle..." gelten. Nämlich die Funktionen der einzelnen Augmentions und die Einschränkung.
Aber selbst wenn du hinter diesem Punkt ein Fragezeichen setzt, ist die Aussage auf dem Stratagem selbst ausreichend:
Hast du zu dieser Frage eigentlich auch selbst eine Meinung?
Oder möchtest du nur aufzeigen, dass GW schlechte Arbeit abliefert hat??
Die Detachment Rule bezieht auf "At the Start of the Battle.....". Die Restriktion "Duplicated augmentations have no additional effect" gilt damit nur am Anfang der Schlacht, sie hat während der Schlacht keine Wirkung mehr.
Ich würde in diesem Zusammenhang gerne mal diskutieren nach welchen Kriterien du den Regeltext aufschlüsselst, und welche Sätze und Bedingungen der Regel 'Experimental Augmentations' deiner Meinung nach wann gelten und wann nicht. Kannst du das mal bitte aufzeigen?
Meiner Meinung nach ist dank der Formulierung "then select one augmentation (see Experimental Augmentations)" die Sache so geregelt, dass man für die Auswahl der Augmentation den Passus "Experimental Augmentations" vollumfänglich berücksichtigen muss.
Inklusive "Duplicate augmentations have no additional effect".
GW liefert immer schlechte Arbeit was Regeln angeht, das ist allgemein bekannt, das muss ich nicht mehr aufzeigen
Wann lernst Du es endlich, nicht Deine persönliche Meinung als Faktum hinzustellen...bitte derlei provokante Formulierungen unterlassen!
Wunderbar! Sehr guter Witz zum Einstieg in das neue Jahr! Ich freue mich auf die weiteren, die Du dieses Jahr bringen wirst ?.
Du weisst ganz genau, dass Du das sein lassen sollst! Lass Dich einfach nicht provozieren...
Bitte in gesittetem Ton weiter diskutieren, sonst geht es hier zu. Danke!
