Zumal damit die letzten beiden überlebenden Symbionten eines Trupps (wenn es genau diese beiden Modelle mit den Maws sind) auf einmal deutlich gefährlicher sind im NK. Bei einem 10er Trupp werden die 2 möglichen MWs nicht so groß ins Gewicht fallen.
PSYCHIC ACTIONS
While psychic actions are not in and of themselves psychic powers, they function in much the same way. For all intents and purposes, when a unit attempts a psychic action, this is treated the same as if they were attempting to manifest a psychic power, and as such triggers any rules that interact with manifesting a psychic power (e.g. rules that enable you to deny a psychic power can also be used to deny a psychic action). Note that a PSYKER can still only attempt to perform one psychic action in their Psychic phase instead of attempting to manifest any other psychic powers. Note, however, that the range of psychic actions is never modified by any such rules.
MALECEPTOR:
PSYCHIC OVERSIGHT
While this Synaptic Imperative ability is active for your army and a friendly HIVE TENDRIL unit is within 6" of this SYNAPSE model:
- If that unit is performing an action, it can make ranged attacks without that action failing.
- That unit can start to perform an action, even if it Advanced or Fell Back this turn.
- If that unit has the PSYKER keyword, performing a psychic action does not prevent it from manifesting psychic powers.
Das aktuelle FAQ hat es nun geregelt.Kann eine Psi-Aktion zusätzlich zu den möglichen Psikräften gewirkt werden, oder ist sie ein Teil davon?
LG und 1000 Dank
Q. The Psychic Oversight Synaptic Imperative allows units performing a psychic action to still manifest psychic powers. If a unit performs a psychic action, does it count as one of the psychic powers that a unit is allowed to manifest that turn?
A. Yes. Performing a psychic action is treated the same as if attempting to manifest a psychic power and so counts against the number of psychic powers a unit can manifest in that turn.
Würde ich so nicht sagen. Es gibt keine Regel die das so regelt, nur ein FAQ welches so tut als gäbe es so eine Regel. Natürlich muss man das jetzt so spielen aber naja, konsistent sieht anders aus.Das aktuelle FAQ hat es nun geregelt.
Die Psi Aktion wird als Psi Kraft behandelt und zählt gegen die Anzahl der Kräfte die ein Psyker pro Runde wirken kann.
Auslegungssache des Textes:Würde ich so nicht sagen. Es gibt keine Regel die das so regelt, nur ein FAQ welches so tut als gäbe es so eine Regel. Natürlich muss man das jetzt so spielen aber naja, konsistent sieht anders aus.
Könnte man auch ableiten, dass der versuchen einer Psi Aktion eben gegen die max. Anzahl an Psi Kräften zählt.While psychic actions are not in and of themselves psychic powers, they function in much the same way.
