Ein grober Überblick über die neuen Regeln der Codizes aus der Talon-Box (Quelle YT Video) - via Dakka
Fotos im 2. Link
Sagittarii Orientalis
I just watched someone on youtube reviewing the new (thin)codices after unboxing the Talons of the Emperor box.
Rules for Custodians and Sisters of Silence themselves have changed little.
As for Custodians, even those without Storm Shield have basic 5+ invul. Sadly, they still do not have assault grenades.
The Venerable Contemptor Dreadnought has, obviously, the Venerable special rule with stats same of that of Space Marines.
However, just like its infantry brethrens it can Deep Strike.
The Venerable Land Raider is 10 percent more expensive than basic land raider, but has 5+ invul like Custodian Guard.
In addition, it ignores crew shaken & stunned results and BS5. Needless to say, it also has Venerable Special rule.
The unique detachment for Custodians allows you too also take the dreadnought, and has new benefits.
One of them is allowing your deep striking units to roll only a single d6 when they scatter, and re-roll deep strike mishap table.
Sisters of Silence are now divided into 3 separate units depending on equipment.
The unit with greatblades are the cheapest, the bolter unit same as before, and the flamer unit most expensive.
The most notable change, in my opinion, is that the Sisters' Rhino also has Psychic Abomination special rule for only 10 more points.
So basically if you take a unit of sisters and a dedicated Rhino, you have two units onthe battlefield which can nullify psychics.
Null Maiden Task Force has also received new benefits like Custodians'.
The biggest bonus is that you can add 3" to the range of Psychic Abomination for every unit on the battlefield after the first.
This means that if you take maximum three squads of sisters and three dedicated Rhinos for them, their anti-psychic range increases to 27" when all the units are on the battlefield. I personally think this detachment is the real winner of this release.
Edit : So this is what "getting Ninja'd" mean. Please refer to the reply right above mine.
Die Kosten dann aber auch entsprechend Punkte. 3 Squads Sisters und noch drei Rhinos, dazu sind die die Schwestern nicht gerade die stabilsten Einheiten. Klar wird die Psi-Phase am Anfang nicht mehr so spaßig wie ohne sie auf dem Schlachtfeld, aber so schlecht sind die T-Dämonen auch nicht, dass sie die Sisters nicht wegkriegen, sobald sie mal ausgestiegen sind.
Ich glaube auch, dass die nicht so häufig auf dem Tisch stehen werden. Beißt man halt mal die Zähne zusammen und flucht die 2 Stunden über GW.🙂
Also ich weiß nicht so recht.
Wenn am Anfang gleich 3 Rhinos da stehen ist die anti Psi Blase 18" von jedem Rhino aus.
Und wirklich Punkte kosten die Sisters und Rhinos nicht wirklich.
Ich glaube auch das die Dämonen sich dann schwer tun die Rhinos ohne Psi wegzubekommen. Und dann halt die Sisters die da drinnen sitzen auch noch.
Die ersten 2 runden wird Psi technisch nicht viel passieren. Sogar ein Magnus kann nurnoch auf die 6+ Warp Charges bekommen sobald er im Radius steht oder fliegt. Und das für die paar Punkte. Ich lass mich überraschen wie sich das tatsächlich spielen wird, aber spannend wird es dadurch sicherlich.
Besonders die Custodes haben es mir angetan mit den ganzen extra regeln. Alle Eternal Warrior ist schonmal ne Ansage. Und die Option auf Land Raider macht die Jungs noch gefährlicher.
Freue mich schon tierisch auf die Jungs und Schwestern
Warum eigentlich?
Ich finde Custodes schon zu groß warum müssen marines immer noch wachsen (sind sie die letzten jahre schon kontinuierlich)
Weil GW die Plastik Menschen nicht kleiner machen wird.
An sich ist es daneben gegangen als man die IA Regimenter auf Plastik umstellte, weil die Metalljungs hatten die richtige größte im Verhältnis zu Marines.
Jetzt wirken die Marines halt zu klein für das was sie sein wollen
Ja, im Endeffekt kann man es keinem Recht machen. Gehste auf true scale meckern die, die ihre Marines gerne als Mini-Dosen spielen. Bleibste auf der derzeitigen Größe sind die anderen, die auf true scale hoffen, enttäuscht. Sie könnten die Fahrzeuge anpassen. Das wäre ein erster Schritt der kaum jemandem wehtun würde und den Übergang erleichtern würde. Und auch neue Kaufanreize schafft.
Das die Custodes zu groß sind ist halt subjektives empfinden. Vom background her müssen sie eben größer sein. Und zeitgleich muss auf dem SPielfeld auch das Gefühl generiert werden das die jetzt nicht o8/15 sind. Visuelles und Haptik ist einfach bei sowas wichtig.
Es gab doch mal Gerüchte dass die guten 30k Mechanicum Modelle in 40k integriert werden sollten (neues Imp. Armor). Gibt es da schon mehr Infos drüber? Oder sogar ein Datum?
Sorry falls das schon irgendwo hier stand, aber habe nix genauers darüber gefunden..
Schwer festzupinnen, der Name von dem Buch ist "Fires of Cyraxus" (http://battlebunnies.blogspot.de/2016/05/forge-world-seminar.html). Leider ist über den Release weiterhin nichts bekannt. Vielleicht diesen Herbst? Da das Seminar dazu jetzt schon einige Zeit her ist, würde ich mich langsam über den Release freuen. Es sollen soweit ich gehört habe so ziemlich alle 30k sachen für 40k geportet werden. Die inzwischen Verbotenen Automata sind dann laut Hintergrund 10k Jahre eingesperrt gewesen und entsprechend etwas verrückt (naja inzwischen sind viele Leute bei 40k so alt, siehe Gathering Storm
). Das eröffnet dann tolle Möglichkeiten für Admech, besonders für Myrmidons und Ordo Reductor, die im Skitarii Codex (oder Cult?) definitiv noch in der Hierarchie erwähnt werden.
