Also der Mitarbeiter in meinem GW-Laden hat mir erzählt, dass es wohl so sein wird, dass die Mini vorerst nur auf einen Tag limitiert ist. Sprich man kann sie erstmal nur am 24.2. online bestellen und ob sie danach noch dauerhaft ins sortiment kommt ist noch fragwürdig.
Genau das ist das Problem 🙂 die Infos widersprechen sich, und eventuell wurde noch kurzfristig entschieden das Modell zumindest online länger anzubieten weswegen auf WarCom etwas anderes zu lesen ist als in den Mails an die Shops.
Tau Gerüchte via BolS
via Haechi (Advanced Tau Tactica)
I lost track of this topic for a while, but Arka told me someone dropped a rumour about Gun Drones not having saviour protocols and Rail weapons being the same price. I can tell you both are false. Although there is a small change to saviour protocols.
Burst-or Iontide…?
Either and both. The firepower of both has skyrocketed while the point cost dropped hard. Plus there’s two insane stratagems for them.
…I have a massive tournament coming in two months and I’m dropping my Custodes and Thousand Sons list to play T’au instead. Also buy Riptides and a couple Hammerheads (with Ion Cannons) if you don’t have them.
The change to Saviour Protocols is something similar to what Crisis Bodyguards do and Shadowsun’s rule with Stealths suits.
Sorry, that was a bit confusing. Savior Protocols is the same as before, but happens only on a 2+.
If people are already complaining about T’au, here a few negative things haha.
1 commander per detachment
No changes to the markerlight table
No improvement to BS across the board
Railguns are the same
Don’t get alarmed though, there are far more upsides that we will get to soon-ish. I’m just waiting for GW to officially announce the codex to get more into details.
The upsides will come from massive point drops on base costs and weaponry, and massive buff to weapons characteristics. Sometimes both, which can make for some crazy stuff. Like a Heavy 18 S6 -1 2dmg gun for 35 points
Wurde nicht gerade das letzte Gerücht mit der Gun schon vor einigen Tagen als Fake enttarnt? Muss ganz ehrlich sagen momentan bin ich was Gerüchte in Richtung Tau, Dark Eldar und Necrons geht extrem vorsichtig und überstreue alles mit sehr viel Salz, einfach weil so viele Knalltüten hervorgetreten sind die den grössten Schwachsinn gepostet haben und jeder hat angebissen, bis sich dann einige Tage danach herausgestellt hat das alles nur ein Fake war.
Eine "schlechteste und überteuertste Waffe im gesamten Spiel" muss es geben. Warum also nicht Railguns? 😀
weil das Teil auf einem Panzer ist und laut Lore als Langstrecken PA Waffe gilt die ein Titan mit einem schuss ausschalten könnte / außerdem ist es die Hauptbewaffnung und der HH besitz keine weitere "Starke" waffe.
wenn ich also die Hauptbewaffnung mal weglasse kann ich bezüglich der Sekundär bewaffnung gleich ein Teufelsrochen nehmen.
im Spiel aber nur 1 Schuss mit W6 Schaden + W3 Crit bei 6er Verwundungswurf macht.
Klar der Longstriek brauch nur 2+ / 2+ und dann W6 Schaden
Normaler HH brauch 4+ / 3+
einfach witzlos für 170-200 Punkte.
Sagt dir der Leman Russ Vanquisher etwas?
Dort würde ich mir solche Werte wünschen. 😉
einfach Normalen Kampfpanzer nehmen ? Enormen Output, und günstiger ?! alleine die LK die bei LR als Sekundär Bewaffnung gilt ist nicht viel schlechter als die HH Rail gun...... Imps die sich aktuell beschweren = Luxus Porbleme.
Zumal der Vanquisher mit Pask Sehr gut ist, halt nur nicht im vergleich zum normalen KP.
Ich bin mir nicht sicher, ob das Argument "Dann spiel halt was anderes!" von deinem Standpunkt aus so gut funktioniert.
Sonst käme man noch auf die Idee auf dein Railgun-Problem mit "Dann spiel halt was anderes!" zu antworten. 😉
Was wäre denn die Alternative bei den Tau ?
ps. Breitseiten kosten auch 210 Punkte haben nur W5 / 6LP
der ist also Deutlich schneller Tod und Tauscht die Große Rail gegen eine Kleine die zweimal Feuern kann aber weniger schaden macht.
Das du nicht mal erkennst das alleine die Sekundärbewaffnung des LR schon der Hauptgewaffnung der Tau Unterstützung Einheiten überlegen ist und gleichzeitig der LR teilweise Günstiger ist zeigt eigentlich das du gar keine Ahnung hast
gut das du hier Kommentare ab gibst aber null im Thema bist und offensichtlich nicht mal die werte der Einheiten kennst ........
Off-Topic ende .....
Die Tau-Gerüchte sind irgendwie komisch. Da klingt einiges sehr unausgegoren. Sollte die Heavy Burst Cannon "nur" 35 Punkte kosten, sagt einem das so noch nicht viel, da man ja die Punktekosten und Regeln des Riptides mit berücksichtigen muss und auch den Ion Accelerator, die einzige alternative Bewaffnung.
Eine Beschränkung des Commanders auf eine Auswahl pro Detachment würde mir vom Hintergrund her sehr gefallen. Früher gab es ja noch den Shas'el als "kleinen" Commander. Ich fände es sehr schön, wenn der wieder zurückkommen würde. Wenn der dann mit BF 3+ herumhüpft, wäre das viel angenehmer. Wenn man dem Commander nun noch verbieten würde, mit vier Waffen durch die Gegend zu springen, wären viele "Probleme" gelöst. Eine Begrenzung halte ich aber nicht für wahrscheinlich. Das gibt es bis jetzt in keinem Codex. Dämonenprinzen-Spam ist ja ähnlich problematisch...
Ich hoffe, dass GW an der Markerlight-Tabelle etwas herumspielt. Die Broadsides müssen um einiges billiger werden, die beiden Flieger fühlen sich nicht richtig an und die Raketenmechanik sollte etwas getweakt werden. Es wäre schön, wenn man mal wieder einen Sky Ray ruhigen Gewissens einsetzen könnte...
@Eisen und llb:
Ist es nötig, dass ihr euch angiftet?
Ein LR mit Vanquisher Cannon und Heavy Bolter liegt bei 155 Punkten, hat T8 W12 und schießt 2x auf die 4+ mit S8 AP-3 DamD6, wobei er 2D6 wirft und den höheren nimmt.
Ein Hammerhead mit Railgun und 2 Gun Drones liegt bei 171 Punkten, hat T7 W13 und schießt 1x auf die 3+ mit S10 AP-4 DamD6 plus potentiellen D3 Mortal Wounds.
Beim direkten Vergleich sehe ich da den Vanquisher schon vorne. Das man ihn dennoch so selten sieht, liegt aber eher an den vielen anderen Waffenoptionen.
