Faction Focus Orks 9. Edition
Anscheinend leaken langsam die Punkte und der erste Blick ist noch nicht so toll für Orks.
Goonhammer hat anscheinend 8te Editions Listen genommen und die Punkteanpassungen damit berechnet.
Orks haben damit eine Preissteigerung von 19,3% erhalten und landen damit auf Platz 21 von 25.
Die Liste dazu findet man hier: https://www.40kstats.com/rumbleinromford
Iron Hands beispielsweise wurden nur 10% teurer. Custodes auf Platz 1 sogar nur 2,6%.
Quelle: https://www.goonhammer.com/the-9th-edition-munitorum-field-manual-points-review/
The Rundown
Much like AdMech, this evaluation is badly skewed by a single change that might be an error. As printed, a Big Mek with Shokk Attack Gun goes up by 40pts, and since there are three in every list, pretty much, that’s extremely bad news. Like with the Skorpius, this looks like it may be due to the gun now supposed to be inclusive but not being zeroed out – a change to 95ppm would seem more realistic, and would be enough for Orks to jump into the so-so category.
It isn’t the only hit they take – while Boyz (and, pleasingly, Kommandos, who should see a lot of play now) get the 1pt treatment, Grots go up by two which makes keeping enough around to shield stuff like lootas (especially now they no longer provide CP) a real pain. Smasha Guns finally go up a more realistic amount per model (though are honestly probably still fine) and having come down to an interesting point cost in CA2019 Flash Gitz are immediately slammed back to being an irrelevant competitor to Lootas and you do kind of have to ask – why?
Orks do still have angles to work with – putting lots of boyz on a smaller build is still powerful, and Kommandos getting the “horde” treatment is a decent help now you’re no longer so pressured to take lots of Troops. The Orktober wagons also all dodge big hikes, so putting a lot of Shokkjumps and Scrapjets on the table remains viable. Ultimately, there’s stuff you can do here but especially as “losers” from the change to army construction, Orks are identifiable losers once you put the Big Mek change on top.
Wenn ich mich nicht verhört habe,:
Hq und named
Ghazzie 300
Wb 70
Sagmek 95
Kffmek 60 (ohne Feld vermutlich...)
Megamek 95
Weirdboy 75
Snikrot 75
Zagstruk 95
Grotsnik 90
Makari 65
Elite
Burnab 11
Kommandos 9
Meganob 25
Nob 17
TB 7
Bikenob 35
Bannernob 85
Painboy 55
Runtherd 40
Mek 25
Troops
Boys 8
Grot 5(wtf)
Fa
Bommdakka 85
Kopta 25
Squigbuggie 110
Kbb 90
Scrapjet 90
Bikes 27
Sjd 100
Stormboyz 12
Trukk 60
Flyer
Blitza 130
Burna 125
Dakka 110
Wazbomm 140
Heavy
Stompa 860
Dread 55
Kann 45
Bw 135
Gunwagon 160
Deffrolla 160
Gork 285
Mork 270
Loota 20
Mekgun 20
Workshop 85
Tatsächlich ist das mit dem SAG eig. nur fair. War vorher ein Monstrum für sehr wenig Punkte. Daher i.O. Die Grotze und die Flash Gitz allerdings...nunja, gerade Grotze mit 67% Punkteerhöhung ist schon dreist.
Ich warte erstmal ab, aber dass die Buggys keine große Erhöhung bekommen haben, liegt eindeutig daran, dass GW immer noch nicht genug verkauft hat...und das hat für mich einen faden Beigeschmack
Und die ausrüstung:
Big shoota 5
Rokkit launcher 10
Rokkit pistols 10
Koptarokkits 25 (wtf)
Megablasta 10
Megaslugga 5
Megakannon 45
Sag 25
Skorcha 15
Skorcha missiles 10
Smashagun 20
Traktork 30
Bubblechukka 30
Kustomsshoota 3
Killkannon 15
Kannon 15
Lobba 20
Grotzukka 10
Supashoota 10
Tellyporta 10
Wazbom kannon 0
Fetter spalta 5
Pk 10
Säge 10 paar 15
Dread klaw 15
Dread saw 10
Tankhammer 10
Power stabba 5
KFF 20
Bei den meisten Sachen hat sich gar nicht so viel geändert.
Die SAG lohnt jetzt eben nur noch mit der Relikt Version, wobei das bei der neuen Deckung eh schon schwierig ist.
Flieger, Boys und Kommandos sind nach wie vor günstig, ebenso der Scrapjet und der Shokkjump Dragsta.
Zwischen den Auswahlen hat sich wohl auch nicht wirklich viel geschoben.
Smashas sind immer noch okay und das was am meisten stört sind die Grotz.
Keine Ahnung warum die direkt soviel teurer werden mussten.
Aber 10 Grotz sind immer noch ein Stück günstiger als 10 Boyz.
Wobei die neue Moral schon deutlich besser für die Grotz ist, daher evtl. verschmerzbar.
Ah okay. Das Problem zieht sich aber durch alle Fraktionen. GW hat wieder mal eine Chance liegen lassen.
Größtenteils wurden die Punkte nur einfach nach oben geschraubt.
Nur die krassesten Sachen wurden anscheinend etwas eingepreist. Wobei sie frühere CA wohl einfach mal wieder nicht berücksichtigt haben.
Das mit den Flash Gits stört mich ehrlich gesagt auch etwas. Grade am Bemalen, schon wieder einmottbar.
Werde wohl mal auf Tankbustaz gehen, die haben ja von den "Big 3 Dakka-Infantrie-Einheiten" gewonnen durch gleiche Bepunktung wie vorher.
Auch Ghaz verstehe ich nicht ganz. Der war doch vorher schon stramm bepreist. Jetzt noch mit der Punktesenkung beim Warboss. Schade. Hatte gehofft, dass er einer der Gewinner sein wird.
Auf was ich noch warte ist, ob der Boss auf Bike nochmal Punkte kriegt oder ob der aufs Abstellgleis befördert wird/wurde.
Was mich am wenigsten stört ist der SAG-Mek und die Smasha Gunz. Bin auch der Meinung, die waren vorher zu günstig.
Und ganz ehrlich, ich hab schon Listen vorgeschrieben für die 9te. Und durch die neue "Detachement-Tax" hätte ich bei der alten Bepunktung wohl auch nur max. einen mitgenommen. Hätte mir aber vielleicht nicht 4 davon kaufen sollen...
Hab hier mal eine Liste gemacht mit den Prozenten:
Battlewagon
12,50%​
Big Mek in Mega Armour
23,38%​
Big Mek with Kustom Force Field
9,09%​
72,73%​
Blitza-bommer
20,37%​
Bonebreaka
14,29%​
Boomdakka Snazzwagons
13,33%​
Boys
14,29%​
Burna-bommer
22,55%​
Burnaboy
10,00%​
Dakkajet
25,00%​
Deff Dreads
22,22%​
Deffkoptas
25,00%​
Ghazzie
0,00%​
Gorkanaut
14,00%​
Grot
66,67%​
Grotsnik
4,65%​
Gunwagon
14,29%​
Killa Kans
50,00%​
Kommandos
12,50%​
Kustom Boosta Blastas
12,50%​
Lootas
17,65%​
Makari
0,00%​
Meganob
25,00%​
Megatrakk Scrapjets
12,50%​
Mek
13,64%​
Mek Gunz
33,33%​
Mekboy Workshop
6,25%​
Morkanaut
22,73%​
Nob
21,43%​
Nob with Waaagh! Banner
13,33%​
Nobz on Warbikes
6,06%​
Painboy
5,77%​
Rukkatrukk Squigbuggies
10,00%​
Runtherd
14,29%​
Shokkjump Dragstas
11,11%​
Snikrot
7,14%​
Stompa
7,50%​
Stormboyz
33,33%​
Tankbustas
40,00%​
Trukk
1,69%​
Warbikers
17,39%​
Warboss
7,69%​
Wazbom Blastajet
41,41%​
Weirdboy
20,97%​
Zagstruk
7,95%​
Big choppa
0,00%​
Big shoota
0,00%​
Bubblechukka
0,00%​
Dread klaw
0,00%​
Dread saw
0,00%​
Grotzukka
0,00%​
Kannon
0,00%​
Killkannon
0,00%​
Killsaw
-33,33%​
Koptarokkits
4,17%​
Kustom Force Field
Kustomsshoota
50,00%​
Lobba
11,11%​
Megablasta
11,11%​
Megakannon
0,00%​
Megaslugga
-28,57%​
Power klaw
-23,08%​
Power stabba
66,67%​
Rokkit launcher
-16,67%​
Rokkit pistols
-16,67%​
Sag
Skorcha
-11,76%​
Skorcha missiles
100,00%​
Smashagun
11,11%​
Supashoota
0,00%​
Tankhammer
0,00%​
Tellyporta
-9,09%​
Traktork
0,00%​
Two killsaws
-34,78%​
Wazbom kannon
-100,00%​
Ich bin dankbar über deine Liste. Aber ich finde sie etwas unaussagekräftig, wenn ich darüber motzen darf.
Grade bei den Einheiten, welche eindeutig nur eine Bewaffnung haben können. SAG-Mek inkl. Waffe ist z.B. 50% teurer geworden, nicht 70%+. Oder Tankbustaz sind inkl. Waffe imho gleich teuer geblieben.
Mal sehen. Ich hoffe mal, dass BS schnell nacharbeitet! ;-)
Edit: Was ich spannend finde: Meganobz mit Klaue und Kustomshoota kosten jetzt 38 Punkte, mit Doppelsägen 40 Punkte. Werde jetzt mal alles auf Doppelsäge umstöpseln.
