Kleine Ergänzung: normaler Schaden wird immer einem einzelnen Modell zugewiesen. Wenn das nur einen Lebenspunkt hat, aber 6 Schaden von einer einzigen Attacke bekommt, verfällt der Rest. Mortal Wounds werden in der Einheit verteilt.
10. DECLARE RESERVES AND TRANSPORTS
These missions use the Strategic Reserves rules.
Both players now secretly note down on their army roster which of the units in their army will start the battle in Strategic Reserves, which of their units will start the battle in a location other than the battlefield (if a player has access to any Stratagems that enable them to set up units from their army in a location other than the battlefield, they must use such Stratagems now), and which of their units will start the battle embarked within TRANSPORTmodels (they must declare what units are embarked on what model). When both players have done so, they declare their selections to their opponent.
No more than half the total number of units in your army can be Strategic Reserve and/or Reinforcement units, and the combined points value of all your Strategic Reserve and Reinforcement units (including those embarked within TRANSPORT models that are Strategic Reserve and/or Reinforcement units) must be less than half of your army’s total points value, even if every unit in your army has an ability that would allow them to be set up elsewhere.
In Eternal War missions, Strategic Reserve and Reinforcement units can never arrive on the battlefield in the first battle round. Any Strategic Reserve or Reinforcement unit that has not arrived on the battlefield by the end of the third battle round counts as having been destroyed, as do any units embarked within them (this does not apply to units that are placed into Strategic Reserves after the first battle round has started).
Grundsätzlich ja, doch das hängt vom Wortlaut ab. Ich meine Caps und Lt.s betreffen nur CORE und damit nicht sich selbst.1) Gelten die Reroll Auren von SM Captains und Lieutenants auch auf sie selber?
Ja, du brauchst lediglich Sichtlinie und Reichweite.2) Können Modelle durch freundliche Einheiten durch schießen? Also sie sehen nen Fuß, nen Arm, etc. von der Feindlichen Einheit aber es stehen halt ein paar befreundete Modelle in der Schusslinie.
Ja, wer im Gelände steht, bekommt den Bonus ohne weitere Bedingungen. Nur Dense Cover (-1 to hit) fällt hier raus, da man den Abzug ignoriert, sobald man selbst in dem Geländestück steht.3) Hat eine Einheit die in einem Gebäude steht auch Deckung wenn sie von einer anderen Figur, die auch im Gebäude steht beschossen wird?
| BLESSING: Da Jump has a warp charge value of 7. If manifested, select one friendly <CLAN> CORE unit that is within 12" of this PSYKER. Remove that unit from the battlefield and set them up anywhere on the battlefield more than 9" from any enemy models. |
Darf der HQ angegriffen werden ohne das vorher ein Angriff angesagt wurde1. Ja
2. Ganz regulär mit allen anderen Einheiten, die in diesem Zug nicht angegriffen haben (sofern keine anderen Sonderregeln dazwischenfunken).
ProfessorZ
Ja, das geht. Die Aktion startet erst am Ende der Bewegungsphase. Davor kannst du dich mit der Einheit bewegt haben einschließlich des Aussteigens aus einem Transporter. Die generellen Regeln für Aktionen verbieten nur das Durchführen, wenn die Einheit vorher vorgerückt ist oder sich zurückgezogen hat. Die konkrete Aktion selbst regelt dazu auch nichts abweichendes.Kann man standarten aufpflanzen wärend man vom impulsor ausgestiegen ist Oder drop pod
Ja Sie kann von Einheiten die ein Charge durchgeführen haben angegriffen werden.Darf der HQ angegriffen werden ohne das vorher ein Angriff angesagt wurde
Ja, klar, gilt das noch ...inkl. der FAQs zur neunten Edi hier.😉Ist das Codex Supplement Imperial/Crimson Fists aus der 8. egtl. noch gültig? Weil es gibt ja noch kein neues. Und bei Battle Scribe kann man noch die Relics aus dem Supp ausrüsten zum Beispiel. Deswegen bin ich mir da unsicher.
