S. 224
CHARGING WITH A UNIT
Once you have chosen an eligible unit to declare a charge with, you must select one or more enemy units within 12" of it as the targets of its charge. The target(s) of this charge do not need to be visible to the charging unit. You then make a charge roll for your unit by rolling 2D6. This is the maximum number of inches each model in the charging unit can now be moved if they can make the charge move. To make a charge move, the unit’s charge roll must be sufficient that it is able to end that move in unit coherency and within Engagement Range of every unit that was a target of its charge, without moving within Engagement Range of any enemy units that were not a target of its charge. If this is possible, then the charge is successful and the models in the unit make a charge move so as to fulfil the above conditions. If this is impossible, the charge fails and no models in the charging unit move this phase.
