Da gibt es viele verschiedene Ansätze. Wie wäre es mit "max.12 MasteryLevel pro Armee"?
Hier noch ein anderer Interessanter Ansatz vom DakkaDakka Forum:
The maximum dice any unit can only use his Warp pool per psychic phase is 2x his Mastery Level. For example, a Level 3 Daemon Prince can only ever use a maximum of 6 dice from the warp pool. So why this change as opposed to a hard limit (say, maximum of 12 dice or 20 dice or whatever)? Because if you set a hard cap, there will be a bunch of units sitting around doing nothing whereas the units with all the good powers basically can always get off their powers. For example, say you have a Lvl 3 DP with the Summoning, Invisibility and Cursed Earth. Without limitations, he can problaby use 19 out of the 20 dice pool to get all 3 powers off. But if he can only use 6 dice, now he's got a more difficult choice to make in terms of casting powers. Meanwhile, in the original scenario, if he had used 19 dice, all the pink horrors and other psykers in the army wouldn't be able to cast any powers. But with the 2xLevel limitation, now every psyker will have a reserve to ensure that they be able to cast at least 1 power.
